97 honda accord swap
Old Oct 17, 2010 | 08:17 PM
darrinirox's Avatar
Icon2 97 honda accord swap
i have a 97 honda accord and i want to swap the f22b2 for the h23a dohc vtec would this motor bolt directly to my automatic transmission?
Old Oct 18, 2010 | 09:06 AM
nus_dogg's Avatar
Default Re: 97 honda accord swap
Yes, it will bolt right up, but the gear ratios will be too long. If you're staying Auto, I'd invest some money into an H tranny.
Old Oct 18, 2010 | 04:14 PM
darrinirox's Avatar
what the bad? what could happen if i use my f22 auto trans on h23 motor? i understand that the gearing ratio is different but could it mess up anything?
Old Oct 18, 2010 | 04:50 PM
tommygun89hb's Avatar
Nothing bad, You just got to think this car is over 10 years old and the autos in these cars are tired and worn out. There is a chance that you will run into tranny problems in the future.
There are countless people that have dont a swap and overlook the tranny and then their car breaks down and they are mad or its gets left on the side of the road.
Just take that into concederation thats my 0.02
Old Oct 18, 2010 | 08:23 PM
darrinirox's Avatar
but five thousand mile ago my transmission had went out it wouldnt shift out of first gear..so i had the entire tranny rebuit and i put a shift kit in it. and also is the motor mount exactly the same?
Old Oct 18, 2010 | 08:33 PM
nus_dogg's Avatar
You'll need a Driverside Hasport or a Driverside Prelude mount for the swap. All the other mounts will work.
And of course, nothing is bad by using an F22 tranny on an H22 engine. Just that the gears are different and longer like mentioned above.
Old Oct 19, 2010 | 07:05 PM
darrinirox's Avatar
Icon2 Re: 97 honda accord swap
what year honda prelude motor mount? what wire harnest would i have to get witch ones are interchangable with my car?
Old Oct 20, 2010 | 04:40 AM
nus_dogg's Avatar
93-96 Prelude Timing Belt side mount.
RMX_EF9
Aug 23, 2011 02:07 PM
Linkiss
Jun 27, 2009 07:30 AM
DAfanatic
Jan 1, 2009 08:38 PM
thrill
Nov 25, 2003 04:08 PM
Fired Honda
May 17, 2003 09:36 AM
