Synthetic, high milage or normal oil?
Old Oct 17, 2010 | 11:24 AM
spartans2's Avatar
Default Synthetic, high milage or normal oil?
i was wondering what kind of oil is good for my car. its an 01 accord with 147k on it. is it a good idea to go synthetic, high milage, or just stick to the normal oil(5w20). I just use penzoil from the local autoshop.
thanks.
Old Oct 18, 2010 | 10:28 PM
19Accord97's Avatar
Default Re: Synthetic, high milage or normal oil?
Depends on how often you change your oil I suppose.
If you change it every 3k then any oil is fine. However, I change mine every 3k and use a premium filter (Bosch) and Castrol GTX high mileage. But to each his/her own.
Old Oct 18, 2010 | 10:42 PM
nicolaselias's Avatar
Loved
Community Favorite
I would say 3-4k on normal oil is easily safe...
If you want to do 5k or more then look at synthetic
High mileage would be good if you are getting burnoff or leaking, but if neither is an issue just stick to regular oil..
Old Oct 19, 2010 | 12:44 AM
chansta's Avatar
i wouldnt recommend switching to high milage just because cars these days run on very low clearances(cars these days aren't like the old days anymore).
switching to synthetic would be the better option compared to using regular oil for these simple reasons: heat reduction (lower coefficient of friction compared to regular oils = less heat), greater film strength (reduce chances of metal to metal contact), engine deposite reduction(far superior thermal and oxidative stability), engine performance and gas milage are also improved.
Old Oct 19, 2010 | 03:37 AM
TheMuffinMan's Avatar
He knows where you live!
Please search, there are quite a few threads regarding this.
Unless you have a reason to switch oils, there is no need to.
Old Oct 19, 2010 | 08:40 AM
Cactus's Avatar
I use Mobil 1, stock filter, 5000 miles.
Old Oct 19, 2010 | 10:24 AM
wolfy47's Avatar
^^^i wouldnt use a fram filter for 5k.
azzure180
Sep 8, 2009 09:18 AM
io_burn
Dec 30, 2002 05:01 PM
RacerXintegra2k
Sep 12, 2002 11:34 PM
99 HXagon
21
Jul 26, 2002 06:28 AM
Mike D
Jun 23, 2001 07:26 PM
