Washer motors gone bad??
Hi, I am having an issue with a 95 teg ls in which non of the windshield washer sprayer motors work?? Is there a relay or something shared by the both? I don't hear them turn on and get nothing. Thanks for any info.
ES.
ES.
Have you checked the fuse, not just eyeball it, replace it.
It could also be a connection problem, access pump motors, unplug the connector and use a meter to test for ground continuity and power, [12V+ when spray activated].
There is no relay. 94
i did replace the fuse,but it stll doesn't work? I have to test it with a voltage meter next. Thanks for the info.
B_Swapped93
Jan 7, 2013 06:16 PM
97civic07gsxr
Dec 30, 2008 05:07 PM
