Transmission & Drivetrain Gearboxes, Differentials, Clutches
***Need major help with grinding kaaz lsd trans!***
Old Oct 17, 2010 | 12:22 AM
the_branster's Avatar
Icon2 ***Need major help with grinding kaaz lsd trans!***
Just put in a B16 kaaz lsd trans that did not grind on previous owner with a brand new stage 4 competition clutch that is broken in, changed fluids, bled clutch, changed the master slave, and even have full race hasport motor mounts, and I can't seem to think of anyting else I can do to make 3rd gear stop grinding. Any Ideas?
Old Oct 17, 2010 | 09:35 AM
stevenDAtegra's Avatar
Default Re: ***Need major help with grinding kaaz lsd trans!***
It probably grinded 3rd for the previous owner. Only way to fix it would be changing parts that are worn for 3/4 gear.
Just delay your shift to 3rd for a small bit and try to have the rpm as close as possible to where it should be when you let the clutch out
Old Nov 19, 2010 | 04:44 PM
ZDwyer16's Avatar
re synchro it
B00stedEh3
Apr 18, 2011 12:45 PM
MattNYC
Jan 8, 2011 05:55 AM
EvilWuzzle
May 17, 2010 05:53 AM
FastReligion
Jul 10, 2006 05:57 PM
FastReligion
Jul 10, 2006 10:42 AM
