95 Civic hatch - Front brakes locked on - car stops without pressing brake pedal
Old Oct 16, 2010 | 10:31 PM
motrayEG6's Avatar
Default 95 Civic hatch - Front brakes locked on - car stops without pressing brake pedal
i have a 95 civic hatch stock everything brake wise and today on a cruise my front brakes were locked on not fully on but if i was to let off the gas my brakes would stop me without me putting on the brakes, i took out some fluid from the master cylinder and that seemed to help but the same thing keeps happening any help is greatly appreciated a guy on the cruise that helped me told me it happened to his hatch too but he did have a way of fixing the problem.
Old Oct 16, 2010 | 11:03 PM
civicsmoke's Avatar
Default Re: Front brake problem
so your caliper is sticking, either rebuild or get a new caliper
Old Oct 17, 2010 | 05:04 AM
alphalanos's Avatar
dont remove fluid. Take the calipers apart and sand/polish the slide pins with high grit paper and emery cloth. then grease it with hi temp brake grease and reassemble.
Old Oct 17, 2010 | 06:25 AM
nahnah05's Avatar
dont just remove fluid from the master cylinder, it wont don anything other than possibly get air in your brake system them you will have o bleed it. i would suggest making sure that the caliper slides are not stuck. pull the wheel off and shove the caliper back and forth and make sure it will move on the slides a little. if its stuck in one spot take it apart and lube all the slides contact areas. if not suspect faulty calipers, or brake hoses. if you decide to replace the calipers make sure to do the hoses with them it just costs a little extra for some peice of mind and you are right there anyway
Old Oct 17, 2010 | 06:41 AM
motrayEG6's Avatar
awesome thanks for the help im going to get after taking the caliper off and checking it today then thanks again
Old Oct 18, 2010 | 06:16 AM
motrayEG6's Avatar
you said lube all the slides contact areas those r the two points where the bolt is and ill call it the hinge side where the little rubber covers are at?
Old Oct 18, 2010 | 09:26 AM
motrayEG6's Avatar
Default Re: 95 Civic hatch - Front brakes locked on - car stops without pressing brake pedal
grease the bolt the slide part and the caliper piston and feels a little better thats all i can grease up right?
Old Nov 25, 2010 | 06:35 PM
nahnah05's Avatar
yeah it is, sorry it took so long to reply back. how did everything end up?
lxdriver
Dec 17, 2011 10:23 PM
flowgetta
Apr 16, 2009 12:09 PM
kuja396
Jun 2, 2008 05:30 AM
square_1
Jul 2, 2006 09:17 PM
4cylsturbo
Jun 20, 2006 06:37 AM
