CIVIC SI with knock sensor code 23
Old Oct 16, 2010 | 09:15 PM
02spoon's Avatar
Default CIVIC SI with knock sensor code 23
SO I JUST PUT A B16A2 BACK IN MY RECOVERED SHELL AND GOT A 23 CODE OR P0325
FOR KNOCK SENSOR.
REPLACED IT AND LIGHT STILL COMES ON
STILLS RUNS CODE 23
I DISCONNECTED THE BATTERY FOR 1 HOUR
DIDNT WORK
SO I HAVE MY FRIEND BRING HIS HANDHELD SCANNER AND ERASED IT STILL A CODE
i AM SO DONE WITH IT PLEASE IT BEEN TWO AGONIZING WEEKS WITH THIS PROBLEM
PLEASE HELP
Old Oct 17, 2010 | 05:54 AM
canadaek's Avatar
Default Re: PLEASE HELP CIVIC SI
check the wires from the ecu to the knock sensor. if your timing is way out or you have mechanical noise in the engine it can set this code also
Old Oct 17, 2010 | 07:45 AM
Former User's Avatar
Default Re: CIVIC SI with knock sensor code 23
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
Old Oct 17, 2010 | 09:20 AM
HondaPartsHero's Avatar
Technical Hero
I would run a wire from the knock sensor directly to the ECU's pin location and see if that solves it, if it does then you know the problem is in the wiring
Old Oct 17, 2010 | 09:48 AM
TwoFacedCustoms's Avatar
^x2
Doesn't have to go through to firewall or anything crazy...just the quickest way to check the wire without snatching out the multi-meter.
Did you replace it with a new one or just one you or a buddy had laying around?
holy smokes bbq
Oct 7, 2012 05:15 AM
jdmland
Sep 4, 2008 11:17 AM
EF_FEVER
Feb 22, 2007 12:32 PM
93sidelsolvtec
Jan 22, 2007 03:50 PM
roadawg
Feb 11, 2004 01:10 PM
