Balance belt tensioner Removal
Old Oct 16, 2010 | 07:31 PM
nzdm_Eg's Avatar
Default Balance belt tensioner Removal
Can I removed the balance belt tensioner on a h22a engine and just leave the stud bare and will the timing belt pulley work without problem or is it likely to come loose??
Thanks
Old Oct 16, 2010 | 07:33 PM
Acidcrakker's Avatar
Default Re: Balance belt tensioner Removal
U dont need the balance shaft belt if thats what ur asking
Old Oct 16, 2010 | 07:36 PM
nzdm_Eg's Avatar
What ive done is removed the balance belts and both the pulleys from the end of the balance shafts to gain clearance for an h2b eg swap. And I have removed the pulley that tensions the balance belt.
So the bolt that holds the timing belt tensioner has a little nut on it and then its a bare shaft. doesnt look like the timing belt tensioner will come loose but I just wanted to confirm/See if anyone else had done it like that.
dleccord
Apr 13, 2020 08:03 AM
somick
Feb 18, 2017 10:40 AM
SkylineKin
Aug 23, 2009 07:04 PM
TravisCadello
17
Apr 18, 2009 06:18 AM
TodaSi
Jul 16, 2002 03:06 PM
