98 h22 ek forsale...
ill make this as painless as possible on the price to save the haggling and the lowballers. price is $4000. FIRMMMMMMMMMMMMMMM!!!!!!!!!!. had it up for sale before and pulled the add do to tire kickers and low ballers. guys please be upfront about if your truly interested in buying my car. im an honest guy and will not waste your time so please dont waste mine. thanks for reading my small rant. onto the car.....
98 civic hatch cx with h22 swap roughly 12-13k on rebuild.
avid mounts
3in blox velocity stack
3in aluminum tubing
tapered bore T/B
ported stock manifold w/ butterflies and cross bar removed
bars holes where drilled/tapped and then plugged
egr plate
rebuilt stock head milled .010
stock cams
tri y 2.5in header
2.5 cat less exhaust into a vibrant flat black muffler. "nice and quiet when crusin"
msd blaster SS coil
msd wires
bnr fittings braided clutch line and fittings
act 6 puck clutch and PP
solid aluminum shifter bushings "no worry shifts"
hasports stg 1 axles
new walbro 255 pump
92-95 front seats
skunk2 anniversary heavy weight shift ****
stand alone autometer shift light with 7 series pills
autometer dual pod cluster gauge bezel
autometer cobolt mech oil pressure gauge with a/n fittings and -3 line used.
plx sm-afr wideband less then 2k on new o2 sensor
nice pioneer head unit that is not installed just sitting in place
neptune demon rtp installed in a p28 ecu" has a GREAT street tune on it from base.op1320 running closed loop. "has not been fully tuned". painted mirrors
painted side moldings
painted door handles
painted side skirts
factory manual rack
factory manual windows
factory non a/c car
heat works great
honda oem pass. air bag delete tray
ground control coil overs w/ 4 ways up front and 10 way adj. out back.
skinnykids fab shop traction bar powder coated gloss black and anodized gold. all grade 8 and heim joints
original paint that really shines up Very nice, of course has a few rock chips,scratches and a few dings and one dent on divers fender.
absolutely NO RUST. this car has never seen a winter out side of the garage. im sure im forgetting things but that all for know will update if i didnt post other things. can get more or specific pics if needed. thanks for lookin guys. jim.
NO TRADES PLEASE.
ALSO THE CAR WILL COME WITH 14IN STEELYS NOT THE RIMS IN THE PICS..
avid mounts
3in aluminum tubing
tapered bore T/B
egr plate
stock cams
tri y 2.5in header
msd blaster SS coil
msd wires
new walbro 255 pump
92-95 front seats
painted side skirts
factory manual rack
factory non a/c car
heat works great
NO TRADES PLEASE.
Last edited by Double_Trouble_99; Oct 18, 2010 at 06:29 AM. Reason: needed to post more info on car "parts"
couple times but never got a good pass off. didnt preload well enough on the only run that i went to give it my all and broke the axle on 23in slicks. g/l with your build.
if i didnt have a ek and doing a swap. this thing would be mine! lol. im sure someone is gonna pick this thing up quick. 4g's for a clean h22 ek hatch is dirt cheap!!!!!!!!!!!!!!!!!
hey buddy i thought you were going to boost it? well either way if this is around in another month or two i might pick this up off of you i need a nice dd and for those who are interested ive seen it in person and seen it run down the track very clean car and fast too!!
i go home to north west burbs all the time im just over the boarder in iowa right off I80. only 2.5 hour ride from chitown. so come on over and drive her home lol. thanks for the bump
No motor is gone but I still have the trans. Will be putting up a parts thread ith all the parts that I have once the car sells. Thanks for the bump!
just wanted to post that i cant hold the car for anyone guys unless there is a deposit. ive had a few pm's asking to hold on the sale based on people saying they will pick it up. if no deposit its first come first serve. hope everyone understands. car was put up with a no haggle/bs price. thanks fellas,jim.
