d2 stuck on hard
hello,
i have installed D2 coil overs a year ago , which came with keys to adjust the softness and hardness (damper), the ride seemed too bouncy for normal driving so i taught of making it softer,
now the problem:
the long key thingy which comes with the kit worked fine on 3 coil overs but my driver side coil over does not seem to be adjusting, the key just spins freely with out clicking and because of that 3 suspension is in soft setting and one is in full hard setting,
what could be causing the key to spin freely ? and how do i fix it????
now the problem:
This sounds like a technical issue that you should speak to D2 Racing about. They have great tech support and they should be able to help answer your question faster.
www.d2racing.com
Good luck!
www.d2racing.com
Good luck!
rpc08
Sep 5, 2007 10:27 AM
Spade
32
Jun 14, 2002 03:28 PM
