need a mechanic in 562 area
Old Oct 16, 2010 | 01:58 PM
MdMaxPluR's Avatar
Default need a mechanic in 562 area
help.. my water pump was leaking so i decided to change it out.. now i cant put the belt back on.. i need someone to finish the rest of the project.. which includes:
putting the belt on and tensioning it, setting TDC, installing the covers back and the crank shaft pulley.. and start the car.
I will:
install the power steering myself, and remove everything.. the timing covers,belt, everything will be removed for it to be easier.. the waterpump is already installed.. im located in long beach,ca hit me up 5623884896
MdMaxPluR's Avatar
Default Re: need a mechanic in 562 area
i got a really clean spoons strut bar i can give you for doing it or i can give you cash..
Old Oct 16, 2010 | 01:59 PM
MdMaxPluR's Avatar
you must have the tools also..
Old Oct 16, 2010 | 02:05 PM
frank_el_tanke's Avatar
what kind of car/engine?
Old Oct 16, 2010 | 02:06 PM
95ProjectEJ1's Avatar
Hit up beroll_eg6
Old Oct 16, 2010 | 02:19 PM
MdMaxPluR's Avatar
ls motor dc4
Old Oct 16, 2010 | 02:29 PM
PilotOnDubs's Avatar
did you set the engine to TDC before you removed the t-belt?
Old Oct 16, 2010 | 03:20 PM
jdm_bones's Avatar
Cash is king might be able to do this tomorrow, as it is late already...Let me know
Old Oct 16, 2010 | 04:20 PM
cancel's Avatar
I will:
i hope you set the TDC before pulling off the belt.. its doable but its always best to set first.. i could offer to do this but im busy this weekend :[
untitled23
Apr 12, 2010 03:08 AM
DJNauTicz
Mar 26, 2007 10:04 AM
daLixz25
Oct 22, 2004 05:28 PM
turrismaldon
Oct 29, 2002 07:33 AM
Chairman Kaga
Oct 2, 2001 12:33 PM
