CEL 16!!!! Please Help
I have a 91 ef with a b18a1 swap with obd0-obd1 conversion. After replacing my frayed o2 sensor, CEL 16 decides to pop up. Since then I have checked the injector wires and each injector is getting power to them except that when I have the rail off and switch on the ignition none of them open up and spray, but there is enough pressure to push out the injector closest to the passenger side. I am lost and dont know where to go next.
any help would be appreciated, thanks!
Your fuel pump will prime once your key is turned so that would push out your injector. make sure you check for ground ground/power ( find you injector power wire bundle also make sure you didnt rip it apart by chance somehow. although it should be far from where you were working on the o2
skaternak
Jul 18, 2009 06:55 AM
thefazio
Dec 6, 2005 03:38 PM
