98 hx planning b18b1 swap - Will my hx harness work?
Old Oct 16, 2010 | 07:24 AM
Alexpbnj's Avatar
Default 98 hx planning b18b1 swap - Will my hx harness work?
I have a 98 hx and I purchased a b 18b1 swap and he gave me the ecu with it and said my harness should work, but I'm not sure if that's correct because I have a egr valve and whatever on my current harness will this cause any problems? Thanks - alex
Old Oct 16, 2010 | 07:33 AM
Alexpbnj's Avatar
Default Re: Just wondering if my harness will work
He said my harness will plug right into it so I'm not sure if it will work would I havea check engine light on because of this?
Old Oct 16, 2010 | 08:54 AM
HondaPartsHero's Avatar
Technical Hero
Assuming this is a five speed You'll have some extra plugs left over (ie EGR). You'll have to rewire the primary O2 sensor and extend it to the rear of the exhaust manifold pipe in front of the cat. You can just leave the EGR wire hanging as the LS ECU won't look for it because it doesn't use one. You'll also have to either swap plugs on the intake air temp sensor or route the sensor into your intake arm using a grommet. Also you'll need to extend your 2nd O2 into a cat type setup.
Old Oct 19, 2010 | 06:49 AM
Alexpbnj's Avatar
Default Re: 98 hx planning b18b1 swap - Will my hx harness work?
I know the egr plug won't be used neither will anythingwith vtec involved. I'm just wondering if it is hard to swap the intake air temp sensor would my hx plugs work ? If not how hard iis it to move them using a grommet I'm sorry I'm new to this and am just trying to figure out what id need to do before attempting it.
FEEDBACKS APPRECIATED !
Old Oct 19, 2010 | 09:20 AM
Alexpbnj's Avatar
ttt
Old Nov 6, 2010 | 05:48 AM
fleabag's Avatar
can you PLEASE not cut up that harness and just sell the harness along with all the other parts attached to your engine?!
Old Nov 6, 2010 | 06:11 AM
h22preludevtecx's Avatar
The wiring harness will work with a few extra plugs like everyone says unless your running an obd2 ecu also?
Old Nov 7, 2010 | 09:49 AM
Jimster480's Avatar
If your doing a B18 OBD1 Swap then you should be ok. But like previously stated, the plugs will need to be extended. Although it might be cheaper to just swap another harness.
1995integraGSR
Nov 20, 2014 05:21 PM
civicSIhatch93
Oct 5, 2012 06:53 PM
USDM-EK4*
Aug 26, 2009 04:35 PM
Timster87
Jan 6, 2008 10:19 AM
