Strobe Light's for civics
Old Oct 15, 2010 | 08:06 PM
Tong.Y's Avatar
Default Strobe Light's for civics
i'm wondering if there are any strobe light out there that are available for eg civics? anyone know anything about them flashing stobe lights?
Old Oct 15, 2010 | 08:09 PM
EJeff8's Avatar
Default Re: Strobe Light's for civics
My friend has a pair in his De ville.
Buy a set of $10 strobes. Drill a hole as close as you can to the middle of your headlights so they reflect right (they won't work right if they're too far off) and mount them in.
Simple install.
Old Oct 15, 2010 | 08:12 PM
Tong.Y's Avatar
Simple install.
you think you could find me a kit on ebay or something?
Old Oct 15, 2010 | 08:13 PM
Deetz's Avatar
Crazy Honda Guy
i hope you know they are not legal to use on the street
Old Oct 15, 2010 | 08:15 PM
EJeff8's Avatar
^They are legal to use when stopped, with the engine off and in a parking lot though. You should've seen my friend and this security guard go at it haha.
Old Oct 15, 2010 | 08:16 PM
EJeff8's Avatar
Go to autozone and buy a pack of strobes...
Old Oct 15, 2010 | 08:19 PM
Deetz's Avatar
Crazy Honda Guy
that's not really using them on the street, lol
Old Oct 15, 2010 | 08:23 PM
EJeff8's Avatar
^I was just saying in general and also if you meant streets as in taking the car out in public in general.
Old Oct 15, 2010 | 08:40 PM
Tong.Y's Avatar
having a car show in may.. so i'd figure i should get it
Old Oct 15, 2010 | 08:50 PM
EJeff8's Avatar
Well, there yah go.
Old Oct 17, 2010 | 06:08 PM
Tong.Y's Avatar
oka.. i got some strobe lights from autozone and i can't figure how to install the switches and wirings.
there's only two wires.. red and black.. which goes where??.. it also comes with a on/off switch also
Old Oct 17, 2010 | 06:18 PM
TwoFacedCustoms's Avatar
This sounds like a horrible idea lol...but to each his own.
As far as wiring...and the switch...red..positive...black...ground.
The ground can be attached to the body at any good grounding point i.e. bare metal...and the switch is probably on the red wire I'm assuming? somewhere in the middle...well the end of the red wire should go to some 12v source...there's a right way and a semi-ghetto way to do it.
I don't know about EGs but on the EK internal fusebox there is auxillary hookups along the top...I use mine to power my carPC and touchscreen...if you have those use them...if not....
...you can pull out a not so important fuse and wrap the red wire around a fuse leg and put it back in....
Don't these kits come with a little black box that has a strobe speed control too? I had to un-install one on a maxima for a girl I was in high-school with.
Take a picture of the kit *out of the box* with all the switches and wires it contains and I can give you more exact directions....
and if anybody can verify if the EG has those aux plugs in the fusebox or not that would help.
Old Oct 17, 2010 | 06:33 PM
Tong.Y's Avatar
the lights are attached onto the speed control box... then all there is a red as black wire and an on/off switch...
all i'm really concerned about really is the switch it's self..
Old Oct 17, 2010 | 06:34 PM
Tong.Y's Avatar
looks exactly like this
Old Oct 17, 2010 | 06:54 PM
redbull-1's Avatar
Old Oct 17, 2010 | 07:03 PM
Tong.Y's Avatar
so the red wire goes through both switches and the black can go to ground?
Old Oct 17, 2010 | 07:08 PM
redbull-1's Avatar
Yes, the red wire will be connected to the switch terminals. In my picture, the red wire should be cut somewhere, or just use additional wire if you need more length.
Old Oct 17, 2010 | 07:13 PM
Scott.'s Avatar
wtf
Old Oct 17, 2010 | 07:34 PM
redbull-1's Avatar
Wiring switches are generally very simple. Here's an example of a simple switch connection on one of my homemade Sumobots. One positive wire (+) is running from the battery and through the switch, the other positive (+) side through some relays and then the motors.
Old Oct 17, 2010 | 07:53 PM
D16SiHatch's Avatar
strobes are the ghey.
unless.. you get legit whelen police strobes and scare the **** out of your friends at parties
Old Oct 17, 2010 | 07:55 PM
EJeff8's Avatar
^My friend with the De Ville has blue ones. He went ghost behind my douchey friend's v6 'Stang once and flicked on the strobes. I thought the kid **** his pants, haha.
Old Oct 17, 2010 | 09:16 PM
Haha I'm sure this was on a not so populated road...at least I hope.
That would be one hell of a ticket...
WAAAAY back in the day I had red neons...beat detected...under my seat...and somebody gave me a blue one and I wasn't thinking...but my friend in the pass seat plugged it up to see if it worked and it did...blinking blue and red...didn't pay much mind to it until cars started to pull over to the side to let me by..........shut off immediately
Old Oct 17, 2010 | 09:19 PM
uberEFtuner's Avatar
If you really want strobes, order a good brand. The autozone ones are crap, they are very weak.
Old Oct 18, 2010 | 05:08 PM
Tong.Y's Avatar
cheap ones are best when you can do little modifications, unlike expensive ones you have to drill wholes onto your head and tail light.... not what i want.
Old Oct 18, 2010 | 05:14 PM
D16SiHatch's Avatar
the cheap ones just look jank though. i mean strobes in general are kind of silly, but if i was to ever do them i would get a whelen product. that's me anyway
