Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Honda Accord Brake Guides
- Honda Brake Modifications
Overview of popular modifications to customize your Honda.
eg - Is the gsr disc brake conversion easy?
but search google has like 5 on the first page. that mostly come here. and its been covered...alot.
do believe its just trailing arms lcas and whole brake setup. might need a new brake line too. just an R and R.
You can convert the hole car to gsr brakes if you want to. Im doing the same but with 99-00 si parts.
Youll the trailings, and brake stuff, e brake lines, and brake lines. if you doing the hole thing you may want to change the master cly and prop valve.
I dont know of any kits, just hit up craigslist and the market on here.
very easy...if you are going to do it i would suggest going ahead and swapping out the stock rotors/pads for something a little more upmarket, otherwise you might as well stick to your drums...
No, as long as you dont change you suspenstion setup.
Hear are a few pics of my conversion on my 95' Coupe.
Stock drum set up
Removed whole trailing arm.
Used stocked trailing arms, just used the disc hub from an LS Integra.
Replaced the bushings while the arms where off. Also painted the arms.
The finished product. Went ahead and replaced the studs with extended Skunk2
Also upgraded my Master cylinder to a 04' RSX Type-S
Hardest part I think was the running the E-Brake cable.
Stock drum set up
Don't need to use your brakes on the street? I have to. I could tell a big difference stopping when someone pulled out in front of me, for example. Maybe it was just in my head, maybe my drums were just shot before I replace them. but I doubt it.
Believe me, its all in your head. I did the rear disc swap on my civic, made absolutely no noticeable difference in braking.
It certainly felt more "substantial" I guess. Like my brake system wasn't wobbly or weak.
Stock drum set up
Stock drum set up
The cylinder & booster is a direct bolt on, and I had to mod. the brake lines a small amount.
I also did a brake line tuck so the labor over lapped anyway.
Quotes from other members here on HT.....
- Nothing wrong with drums. They're 8lbs lighter per side, wear much longer, and are cheaper to maintain.
- You could buy performance shoes for the rear. Porterfield makes them. Ironically enough, most folks just use a new set of OEM pads and freshen up the parts in the rear drum.
That's what I did and it was a noticable improvement.
- The 9.5" rear discs with 7CLP13S calipers have not proven to stop any shorter than a comparable drum setup. Stopping power is a wash between the two.
Myself and many others have used the drums on track cars with no real problems to speak of. I've owned three Civics with the rear drums and a Civic, a CRX, and an Integra with the discs. I've also done several rear disc conversions on Civics/CRXen, so I've had plenty of experience with both.
Most people compare their old improperly-adjusted drums with leaking wheel cylinders, ancient waterlogged fluid, thin drums, and glazed shoes to a newly installed disc setup with brand new rotors, pads, and reman calipers with fresh fluid and bled lines. In that case, sure, the discs are going to work a bit better - but you can't come to an objective conclusion that one is superior to the other with that comparison.
______
