Hose swelling up. related smog fail?
Old Oct 15, 2010 | 02:51 PM
mbulanov's Avatar
Default Hose swelling up. related smog fail?
I was trying to pass smog today and after the test, the guy there brought to my attention this hose swelling up.
It's never done that before. Any ideas on what's causing this?
Also, coming within only 1 point away from failing the emissions test,
What are some of the most major things that cause unburnt fuel?
See photo!
Thanks,
-Mark
Old Oct 15, 2010 | 03:15 PM
hybridmiklo's Avatar
Default Re: Hose swelling up. related smog fail?
the things that cause unburnt fuel is timing.
Old Oct 15, 2010 | 05:25 PM
DR.P3PP3R's Avatar
replace the hose
Old Oct 16, 2010 | 09:52 AM
efb16a's Avatar
The hose needs to be replaced ASAP. Make sure it doesn't swell up again with the new hose, because that means you have a clog in front of the hose itself.. For the smog... Do you have new(ish) spark plugs? Highest octane gas possible? get the car hot so your catalytic converter works better. Change your oil, make sure your air filter is clean, timing is VERY important, as hybridmiklo said.
TreDEE
Jul 19, 2010 05:07 PM
drunkenmaster
Apr 7, 2010 12:04 PM
niwisball3r
Mar 24, 2010 11:25 PM
RSZero1
Mar 28, 2003 05:52 PM
Dan GSR
Jan 22, 2003 03:30 PM
