BIGG AXLE PROBLEMS...HELP!!
Old Oct 15, 2010 | 09:30 AM
wat2drive's Avatar
Default BIGG AXLE PROBLEMS...HELP!!
ok the problem is i break axles when i make a full U-turn OR..punch the gas
the axle pops the cv boot off an my axles ends up in two pieces
its a 91 civic hatch dx
hasport mounts
B20b
LS cable tranny
i have DA half shaft an 91 DA axles i just broke a brand new axle this morning(not refurbished axles)
ALSO WHEN I TURN THE WHEEL TO THE LEFT I CAN FEEL THE BEARING AT THE END OF THE HOUSING ITS SUPPOSE TO SIT INSIDE OF SO I KNO SOMETHING IS TO SHORT
ive tried DC half shaft an DC axles but either way it does the same thing
ive looked around and cant find anybody with the same problem
Old Oct 15, 2010 | 10:08 AM
CRX_RR's Avatar
Default Re: BIGG AXLE PROBLEMS...HELP!!
which side is breaking? Did you remove the dust seal? Maybe you want to keep it on since your having problems with a short axle. your best bet is to use your DC axle because its a little bit longer, but you said it breaks to. so idk, good luck
Old Oct 15, 2010 | 12:06 PM
EF-Devotion's Avatar
since you are using hasport mounts, why not give them a call.
Old Oct 15, 2010 | 01:29 PM
wat2drive's Avatar
driver side ..an i heard dc is shorter then da but i gues it dont matter sence they both break
Dave_Dc2
Sep 23, 2009 11:34 AM
MUGEN_EG95
Jan 25, 2009 05:16 AM
stevenDAtegra
Nov 19, 2008 11:43 AM
full Circling
Jul 23, 2004 11:37 AM
type Gendy
Jan 19, 2003 06:18 PM
