***NEW SYNAPSE DIVERTER VALVES NOW IN STOCK!***
THATS RIGHT! This badboy is finally available and in stock! Here is some info for you guys:
Available models:
16501A DV Series Synchronic Blow Off Valve (No Flanges)
16502A DV Series Synchronic Blow Off Valve Kit for Mazdaspeed 3/Mitsubishi Eclipse/GTR R32/R33/R34
16503A DV Series Synchronic Blow Off Valve Kit for Volkswagen/Audi/Porsche (includes 1" Inlet & Discharge flanges)
16504A DV Series Synchronic Blow Off Valve kit for Top Mount Subaru WRX/STI
16505A DV Series Synchronic Blow Off Valve Kit for Mitsubishi Evo7-X/3000GT (includes 1.25" Discharge flange)
16506A DV Series Synchronic Blow Off Valve Assembly, Retail Kit (includes Aluminum Weld on Flange & 1.25" diamater
Info on DV from Synapse:
Synchronic DV is the first, truly compact, zero-diaphragm, high-flow Diverter Valve with a blistering actuation time measured at 25 milliseconds. MAF and speed density applications can apply the new design in push or pull orientation with the ability to fully re-circulate or vent-to-atmosphere the valve’s discharge.
Features & Benefits:
Patented Synchronic actuator design (in both DV & SB)
– Reacts & opens just under 30ms (millisecond)
– For optimal throttle response and performance
Compact and light weight design for both street and race use
Standard 1/8th NPT brass fittings for air signal ports
Black anodized surface finish
– Preserve the OE look and feel
– Light scratch resistant
– Easy to clean & maintain
Can be used in “push” or “pull” mode to suit driver’s preference
Secure mount feature with newly designed mounting ring clip
Direct bolt-on to all current SB line adapters & weld-on flanges
– Ease of installation
– Application specific kits come with Synapse Boost Connect hoses & fitting
Package includes:
Synpase Synchronic Diverter Valve
1.25" diameter Discharge FlangePositive Lock Clamshell Retainers
Nickel Plated Brass Barb Fittings
Other Necessary Hardware
Click Here for more information and/or to purchase this item!
Available models:
Package includes:
