***NEW SYNAPSE DIVERTER VALVES NOW IN STOCK!***
THATS RIGHT! This badboy is finally available and in stock! Here is some info for you guys:
http://www.iapdirect.com/images/T/16501a.jpg Available models: 16501A DV Series Synchronic Blow Off Valve (No Flanges) 16502A DV Series Synchronic Blow Off Valve Kit for Mazdaspeed 3/Mitsubishi Eclipse/GTR R32/R33/R34 16503A DV Series Synchronic Blow Off Valve Kit for Volkswagen/Audi/Porsche (includes 1" Inlet & Discharge flanges) 16504A DV Series Synchronic Blow Off Valve kit for Top Mount Subaru WRX/STI 16505A DV Series Synchronic Blow Off Valve Kit for Mitsubishi Evo7-X/3000GT (includes 1.25" Discharge flange) 16506A DV Series Synchronic Blow Off Valve Assembly, Retail Kit (includes Aluminum Weld on Flange & 1.25" diamater Info on DV from Synapse: Synchronic DV is the first, truly compact, zero-diaphragm, high-flow Diverter Valve with a blistering actuation time measured at 25 milliseconds. MAF and speed density applications can apply the new design in push or pull orientation with the ability to fully re-circulate or vent-to-atmosphere the valve’s discharge. Features & Benefits: Patented Synchronic actuator design (in both DV & SB) – Reacts & opens just under 30ms (millisecond) – For optimal throttle response and performance Compact and light weight design for both street and race use Standard 1/8th NPT brass fittings for air signal ports Black anodized surface finish – Preserve the OE look and feel – Light scratch resistant – Easy to clean & maintain Can be used in “push” or “pull” mode to suit driver’s preference Secure mount feature with newly designed mounting ring clip Direct bolt-on to all current SB line adapters & weld-on flanges – Ease of installation – Application specific kits come with Synapse Boost Connect hoses & fitting Package includes: Synpase Synchronic Diverter Valve Aluminum Weld on Flange 1.25" diameter Discharge FlangePositive Lock Clamshell Retainers Nickel Plated Brass Barb Fittings Other Necessary Hardware Click Here for more information and/or to purchase this item! |
Re: ***NEW SYNAPSE DIVERTER VALVES NOW IN STOCK!***
Orders shipped and PM's replied. Thank you for your business!
All PM’s replied. Thanks
