Simple Tech: Why is the rev limit on HF so low?
From: Close to West Chester, PA, United States of America
Stock 90 CRX HF.
I think redline is around 6000. Is it something to do with the transmission? The 8 valves? Some other lighter/thinner engine parts that wouldn't handle higher revs?
Just curious. I enjoy the mpg, but want to know.
I think it's more like 5500, maybe lower. My guess is valve springs, considering the whole intake system is tiny the motor probably couldn't make use of higher rpm anyway. I had an E30 Eta that redlined at like 4500 because the intake springs weren't stiff enough to react any faster. The transmission shouldn't have anything to do with it.
With 8 valves and the valve lift/duration equivlent to a lawnmower engine, it would practically choke it itself to death above 5500. Honda never designed it to go fast, just get good MPG. And that it does, and VERY well lolol. -Later,BR
Weird, I got a reply in my email but it's not showing up here...
"Here is the message that has just been posted:
alx_90ef
why are you reving up an hf anyways?
its not meant for that.
swap that weenie engine if you wanna mess around.
alx_90ef
lol, what a clown.
No doubt about the HF. I enjoy it for what it is (in stock trim), I just wondered if there was a way to retain the fuel economy when below 5500, but get extra performance when revving. hmm... sounds like I am talking about VTEC...
Always wanted to (but it's not in the cards at the moment) to swap in the VX (92-95?) VTEC-E motor from the bubble hatches of that vintage. Probably not a hard swap either.
But that's for another thread (search first, I know).
But that's for another thread (search first, I know).I suppose the fuel injectors would be an additional 8, plus putting them all together is 9ish.
Timing belt bracket/mod.
I had to do a little more with my z1 swap in my rt4wd.
Wiring doesn't bother me if I get clear instructions (take these, re-pin into those).
I had a DX before. Only thing I never had was an Si (had 2 DXs, 2 HFs, and then this one, which is one of my 'original' HFs come home).
As stated, valve springs aren't meant to go that high. Probably get a floating valve that smacks a piston. Then no more good gas mileage.
Honestly, if you want pep and speed and want to keep the HF. Then drop in an SI motor. Basically direct swap in with I think 1 depin.
you wouldn't get the same mileage if you did any modifications to improve power, except if you put on a CAI and header. Those increased my mileage because IMO it frees up restriction. And the highest I ever heard of a DX getting is like ~40. In my 91 HF the highest I achieved was 64.1 mpg.
and it is true about the lightening up part. Not only were they going for economy but they were trying to sell the car to the people who couldn't afford the Si. Take for example the back trunk cover and the dash clock and even the passenger mirror. I mean those together have got to weigh 6 maybe 7 lbs. hehehe. They were really trying to lighten the load though.
and whats fun about the HF is that even if you do stress the motor and drive it hard you still get good mileage, but just not the extremely "Toyoto prius, Suck it" mileage that you can get if you drive it slow.
ok then you can get good mileage in a dx, but you still can't get the mileage that I am getting. Sorry but unless you lighten the load on the Dx you just aren't gonna get the High Fuel mileage of the HF.
You would be surprised what you can get when you tune for fuel mileage and not power. A buddy played with his zc/z6 minime and was able to get mid/high 40's.
true...this should just about answer all his questions
D15A2
Found in :
1984-1987 Honda CRX HF Grifin
Displacement : 1,342 cc
Compression : 10.0:1
Power : 60 hp @ 5550 rpm
Torque : 73 ft-lb @ 3500 rpm *** Redline : 6000 rpm
Valvetrain : OBD-0 8/v EFI (HF Model)
Economy : 49/54 mpg
Gear ratios : 2.92/?/?/?/0.65
Final drive ratio : 3.58
Also found in 1984-1987 Honda CRX DX (USA)
Displacement : 1488 cc
Compression : 9.2:1
Power : 76 HP @5500
Torque : 84 ft-lb @3500
Valvetrain : 12v SOHC
Economy : 31-38 mpg
D15B2
Found in:
1988-1991 Honda Civic GL/DX/LX
1988-1991 Honda Civic Wagon Wagovan/DX
1988-1991 Honda CRX DX
1992-1995 Honda Civic LSi Hatch/Saloon (European Market)
1992-1995 Honda Civic DXi Hatch/Saloon (European Market)
1990-1995 Honda Concerto (European Market)
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 × 84.5 mm (3.0 × 3.33 in)
Rod Length : 134 mm
Compression : 9.2:1
Power : 92 hp (68.6 kW, 93.3 ps) @ 6000 rpm
Torque : 88 ft·lbf (12.2 kg/m, 119 Nm) @ 4500 rpm
Valvetrain : SOHC (4 valves per cylinder)
Cam Gear : 38 tooth
Piston Code : PM3
Fuel Control : OBD-O DPFI and OBD-1 MPFI
Redline : 7000 rpm, 6500 rpm rev limiter
Head Code : PM6
ECU Code: PM5/P04
D15A2
Found in :
Economy : 49/54 mpg
Compression : 9.2:1
Power : 76 HP @5500
Economy : 31-38 mpg
D15B2
Found in:
Rod Length : 134 mm
Compression : 9.2:1
Cam Gear : 38 tooth
Piston Code : PM3
Head Code : PM6
ECU Code: PM5/P04
Probably the crankshaft is much thinner and weaker too. I wonder what kind of MPG you could get, if you gutted out all of the interior.
