Did the oil filter part #'s change?
When I lookup our vehicles on Baranco's website it shows two filters for ITR's
1) 15400-POH-305
2) 15400-PR3-004
It was always my recollection that the part #'s were
1)15400-PLM-A01
2)15400-PLM-A02
Anyone know what's up?
1) 15400-POH-305
2) 15400-PR3-004
1)15400-PLM-A01
2)15400-PLM-A02
I'm aware A01>A02's, but how do the POH and PR3 filters stack up (if they're even still available)?
What is the recommended OEM Honda oil filter for the ITR now? Try to find the 15400-PLM-A01 or something different?
I had a case of Purolator PureOnes that I've almost used up (old larger style). Going back to OEM Honda for this next round, and if the 15400-PLM-A01 works good, then that'll also work for my CRV and Ridgeline.
yeah you want the Filtech A01's... i usually try to keep a couple on hand hiding at my store also. thats what i use.
ALL of those part numbers will super secede to whats on hand at that store/parts warehouse.
you can still get hamp which are toyo roki if i remember right. the newer honda filters are all honeywell. if they are better/worse than filtech i really have no idea.
s2000 filters don't really increase any pressure if any since its a similar design to the old honda filters it just depends where its made, might have better filter martial. the newer design on the other hand do in fact increase oil pressure due to their smaller design.
I doubt you will receive the A01 when you place a order from a online Honda retailer. Buy a decent filter like a P1, Royal Purple, Mobil 1. Kind of pricey, but I will never buy a OEM filter again. There are better alternatives out there.
The "increased" pressure from a s2k filter has been discussed in this forum before. It is all a marketing thing.
You're welcome to your opinion, but most knowledgeable people would disagree. In my experience, the OEM filter is better than most aftermarket filters, and you're not going to get any benefit by spending more money for an aftermarket filter. I would not buy an aftermarket oil filter for my ITR.
bobistheoilguy.com
it's not just the oil, it's also how much the engine has that effects drain time. diesels that go 30k between changes also often have 20 quart oil capacities and operate at half the rpm of a gasoline engine
RACEPAK
Apr 14, 2010 07:27 PM
