90 EF DPFI d15b2 to d16z6 swap Q's "just need direction"
Old Oct 14, 2010 | 08:03 PM
GinsterVRT's Avatar
Default 90 EF DPFI d15b2 to d16z6 swap Q's "just need direction"
Hi, I am not a Honda guy but have worked on many in my day so I am not totally Honda illiterate. My friend has a 90 EF and he wants to swap in a Z6 for a turbo project and I said I would help him with it if its not to bad. We intend to use the P20/B000 trans and the axles from the PL3/A000. We also will get all the mounts from the donor car and the harness and the P28 ecu. The only things I need some one to help me with is will we need to do the MPFI swap? If so I won't need the resistor box due to using the Z6 injectors? And I have searched for like a day and can't seem to find an answer on the back motor/trans mount. I know I have to use the mount bracket from the d15 on the driverside and the trans mount from the donor. I also know about the cable to hydro conv, its the same thing VW guys do in MK2's with VR6 swaps. I also know it will need a OBD0 to OBD1 conv aswell. If anyone can help me out with what I am missing or has a good build thread that would be great. I just want to make sure we are on the right track.
Thanks, Dan
Old Oct 14, 2010 | 08:23 PM
efjones9's Avatar
Default Re: 90 EF DPFI d15b2 to d16z6 swap Q's "just need direction"
just get a jumper harness, 4 wire o2 and knock sensor if applicable. when u get the ecu jumper it will have all the instructions with it. i found a lil talk about the subject here: http://www.d-series.org/forums/engin...odb0-obd1.html
and here
http://crx.honda-perf.org/articles/z6swap/z6swap.html
Old Oct 14, 2010 | 08:44 PM
GinsterVRT's Avatar
and here
Ok then, sounds like the best best is to go with the jumper harness. What about this back mount jazz, do I have to bust out the welder?
Old Oct 14, 2010 | 08:59 PM
efjones9's Avatar
naa. just use the l bracket if ur using a hydro tranny. cuz the z6 motor doesnt use the front mount . heres another link. its for b series but its all the same hydro trans info: http://hondaswap.com/hybrid-ed-ef-da...info-ef-50719/
Old Oct 14, 2010 | 09:04 PM
munchies91crx's Avatar
the z6 is very easy to swap in. no resistor box when using z6 injectors. n also you need to be mpfi before you start this swap haha. if u got any really specific questions ask. i did this swap in one of my crxs a while ago.
Old Oct 15, 2010 | 07:22 AM
GinsterVRT's Avatar
Ok guys thanks a bunch. I know this subject has been covered before, I just wanted to hear it from someone who did it.
Old Oct 15, 2010 | 07:48 AM
GinsterVRT's Avatar
Oh and long live the EF, the "WAR DOOR".
Old Oct 16, 2010 | 05:04 PM
GinsterVRT's Avatar
Ok, so if you don't use the resistor box you just tie all the ground together?
I mean positives together.
Old Oct 16, 2010 | 05:17 PM
tie all the grounds to one. you dont need the resistor box cuz ur obd1 injectors.
Old Oct 17, 2010 | 06:30 AM
GinsterVRT's Avatar
Ok, thats what I thought, thanks. I found a good write up here if anyone is interested.
http://www.angelfire.com/d20/hcivic8...d16z6swap.html
Old Oct 17, 2010 | 08:40 AM
yeah thats not bad. me n leon just did it. you should know me. or alteast the car i did this swap in. i used to live in dalzell
Old Oct 18, 2010 | 06:52 AM
GinsterVRT's Avatar
Word, you guys still around? It would be cool to look at one before we start. We got a 94ex drop out with a Z6 complete, trans, Z6 harness, p28, axles, mounts. You may remember a guy named Gerry who has a pretty nice 98 ex sedan that is white, his 4 door is the one we are doing it to. I am avail most nights, I will PM you my number if you are interested. Should be getting started here in about two weeks when all the stuff gets here.
Old Oct 18, 2010 | 08:19 AM
i wish i still lived in sumter, i come help u throw it in. but im up in montana in the air force now. sorry man.
Old Oct 18, 2010 | 08:23 AM
GinsterVRT's Avatar
Oh congrats, where are stationed at? I am still in aswell.
Old Oct 18, 2010 | 10:03 AM
malmstrom i work on nukes. its pretty decent job
Old Oct 18, 2010 | 11:07 AM
singlecamsaint's Avatar
sounds dangerous and world ending in the event of an error
Old Oct 18, 2010 | 03:19 PM
GinsterVRT's Avatar
Congrats again, lots of car wrenchers in the Air Force. G/L and thanks for the help, I will post pics in a seprate thread for everyones enjoyment.
On a side note, Hows that place???
Old Oct 18, 2010 | 08:13 PM
its ****ing cold as **** here! haha other than that montana is beautiful. but yeah haha. hard to source honda parts. im in dire need of a 5spd cable transmission lol
Bipolarcivic
Jun 23, 2013 02:09 PM
tyked15
21
Nov 8, 2010 05:36 PM
mastech
Mar 26, 2010 02:16 PM
adobo310
Mar 9, 2010 08:14 AM
Sinner
Jul 14, 2003 09:19 AM
