Suspension & Brakes Theory, alignment, spring rates....
Shock/spring is popping after replacement
Old Oct 14, 2010 | 08:00 PM
clawhammer's Avatar
Default Shock/spring is popping after replacement
I replaced the shock on my 2001 Civic. I bought all factory parts. I took out the shock/spring myself and took it to a shop to have it put back together since I didn't have a real spring compressor. After I put it back together, whenever I turn the steering wheel the right side the spring/shock is getting caught and the wheel isn't turning freely as it should. The car also seems to have memory steering where it will pull to the left after a left turn, and pull to the right after a right turn.
The only part that was reused was the spring itself. The shock, the mounting plate, the bearing, etc are all brand new, Honda OEM. I've already taken it back to the shop once and watched the owner, a previous Honda master mechanic assembly the shock assembly. I know he's not taking any shortcuts, he's very thorough. What could possibly be the problem? I just don't understand. Why is the shock assembly binding?
Old Oct 18, 2010 | 12:19 PM
clawhammer's Avatar
Default Re: Shock/spring is popping after replacement
In case anybody is curious, I took the car back to the shop, and it turns out that the plate that goes on top of the shock was turned in the wrong direction, that's why it was binding.
jdmwannabe813
Suspension & Brakes
Jan 3, 2012 10:29 PM
punkinbeck
Aug 5, 2010 01:48 PM
BB6-213
Honda Motorcycles
Nov 28, 2008 12:28 PM
seeeya04
Suspension & Brakes
10
Jan 16, 2005 06:24 PM
xXx Justin xXx
14
May 2, 2003 02:24 PM
