Trip OD, Maintenance Req. light
my maintenance req light is on and want to rest it but i seems that the trip od button is not working no matter how hard i press or anything just wondering if i have to take out the whole cluster and do something or if there is any other easy fix. i will print off the wiring schematics tomorrow and try to pin out any connector issue.
The button is probably broken. You'll need to replace the cluster, or learn to ignore the light. If worse comes to worse you could put something over it. Sticker, piece of tape, whatever.
yeah i think that is the rout i am probly going to go (replacing the cluster). i have been looking at those s2k cluster swaps.
****edit just kidding about s2k cluster swap looks way to time consuming.
Originally Posted by It Wasn't Me;
There's no bulb for the maintenance required light. Pretty sure it's an LED wired into the circuit board which cannot be removed.
I have accualy got the light to go off i had to get something that i could push the button in really hard (harder then my hand could) and got it to respond. not sure if gana work again though ha.
captivahach
Aug 30, 2009 05:08 AM
junior_tm
May 6, 2008 08:02 PM
