whats everybody revving their d's to??
Old Oct 14, 2010 | 06:17 PM
GroundZer0 336's Avatar
Default whats everybody revving their d's to??
just wondering what everybody is revving to, boosted, n/a, whatever. been thinking about stepping up my boosted d just dont know what kind of rpm it can handle...
Old Oct 14, 2010 | 06:23 PM
alex14's Avatar
Default Re: whats everybody revving their d's to??
In for responses. I'd like to know for my D16z6 swap.
Old Oct 14, 2010 | 08:03 PM
and post up your setup...
ill start
d16a6, rebuilt, 6k miles
mls hg., arp head studs
cast manifold, t3/t4, 50a/r
8psi, hondata s300 in p28, obd1 conv.,
3 bar map.......2.5 to 3" downpipe, to 3 inch thermal exhaust
rev limiter set at 7k cuz i dont really know what these d's can handle, feels like i can have more power past 7 but dont feel like blowing this motor quite yet...
Old Oct 14, 2010 | 09:41 PM
munchies91crx's Avatar
okay nothing in my current car but here is what i had :p im a z6 prodegy back in sumter, sc
91 crx hf. with full si interior.
d16z6 full swap.
-Head
~Full PnP Shaved. 3 angle valve job
~Custom grind NA cam
~supertech high comp valves
~y8 ported im with matched ls tb
~aem cam gear
~330cc injectors
-Block
~ bored .70 over
~ forged steel crank
~ high compression wiesco pistons
i think there was more. not quite sure.
oh yea full obd1 conversion s200 p28 ecu.
everyone in town though it was a lsv in the crx in it was a little bitty sohc. :p
redline was at 8400rpm i believe. maybe higher.
Old Oct 15, 2010 | 05:28 AM
Todd00's Avatar
I said I don't want a title!
Pretty sure that the OBD-0 distributors don't like to be revved past 8000rpms (bad things happen). This was not an issue for OBD-I distribs.
On my D16a6 I set the limiter to 7800rpms. Dyno charts showed it making power until about 7400rpms. The extra 400rpms is so that I didn't have to shift if I'm in between gears and a corner was coming up.
Old Oct 15, 2010 | 05:51 AM
StayKrafty's Avatar
d15b
skunk2 intake mani
akunk2 exhaust
header
obd1 with P28
Rev limiter is set to 8600, it never sees that far. Usually shift at about 7500.
Old Oct 15, 2010 | 06:56 AM
Joay's Avatar
Friend of mine had a D15B/P28 combo and hit fuel cut (~7400) a lot. Ran like a champ, probably still does but the car was flipped.
Old Oct 15, 2010 | 06:59 AM
kaiba's Avatar
OVER 9000!!!!
Old Oct 15, 2010 | 07:50 AM
slywfbpsi's Avatar
zc vtec
aem short ram, ebay headers, test pipe, 2.5 inch exhaust, pherable chipped ecu set at 7500 rpms.
Old Oct 15, 2010 | 08:00 AM
alx_90ef's Avatar
d series can only handle about 7200
add arp rod bolts and you'll be able to rev alot higher then that.
Old Oct 15, 2010 | 08:52 AM
singlecamsaint's Avatar
7000 is good enough for me
Old Oct 15, 2010 | 10:10 AM
alex14's Avatar
Originally Posted by kaiba
OVER 9000!!!!
Old Oct 15, 2010 | 10:45 AM
D16SiHatch's Avatar
if the cam is stock and valvetrain components are stock their is no reason to rev it beyond the stock redline.
Old Oct 15, 2010 | 01:25 PM
jdm ef8 89's Avatar
7,500 club
but still dont ever rev it that high cause id like my motor to be a non smoker.
Old Oct 15, 2010 | 05:28 PM
DR.P3PP3R's Avatar
3.5 k stock d15b1 260xxx miles
Old Oct 15, 2010 | 05:29 PM
BiG ChOr!Zo's Avatar
30000k
Old Oct 15, 2010 | 07:17 PM
think ill just leave it at 7k for now, going to be doing a good vitara build and use bisimoto valve train this winter. for you boosted guys looking at this, what kind of boost are you running/what can d's take? thinking about going to 10, or 12. if it was close to tax time id just got ahead and up it now, but dont really wana blow it up yet haha.
managon_5
14
Aug 16, 2017 03:29 AM
paulzy
10
Dec 30, 2005 11:41 PM
Dancing is Forbidden
Sep 6, 2004 03:36 PM
jazz215
Jan 7, 2003 01:40 PM
KevronsEG
Nov 28, 2002 12:16 PM
