I need a B20 block shipped to me.
I am purchasing a Portflow head with the combustion chambers taken out to 84mm, so I won't be able to use my 81mm b16 block. It would have to have matching mains, crank, rear main seal, water neck, and good cylinder walls. Please pm me, or just post here if pm'ing is too much for you.LOL
All I really need is the block without the rods and pistons. I.E. (Block, crank, main caps, water neck, and thermostat housing) I just want to hone it, clean it, drop new pistons/rods in it, put a head on and tune. I have everything to do that other than the above listed parts.
That depends entirely on the set-up. if I can trust the build and the components, then I could see spending a bit of money. I have built many motors, so I won't pay a ton more for an assembled motor versus a bare block. But you have been pm'd.
check pm.. I have an 86mm sleeved and bored block with pistons ... you jsut need ot assemble. I can sell rods and crank too if you want. pm me back.
