door locks randomly wont work
I'm trying to sell my integra DB8 and I have keyless remote installed. The unlock and lock button will work on both the remote and the door panel. The cars siren beeps as well. But then it will randomly not work. Niether the door panel switch or the remote. The car will make the siren beep still so I'm rulling out the remote being the issue. If I press the unlock/lock switch when it doesn't work I hear a buzz noise inside the panel. Any ideas what is causing this?
If they are stock power door locks then it will be a dealer part, although you can replace it with an aftermarket actuator but you will lose central locking.
http://www.thefind.com/cars/info-acu...egra-door-lock 94
Well I tried to press the passenger front door's lock swiitch and it made a click noise on the driver side. I can still manually lock them. Does that mean I need both driver front and passenger front?
Or did I misunderstand that the problem is only with the drivers door?
If the problem is with both doors and both door switches, then the problem is most likely the "Power Door lock Control Unit"... http://shop.ebay.com/i.html?_kw=94+i...ck&_kw=control 94
None of the 4 doors lock with the power. Only maually. If I click either the passenger or driver side switch I hear a click on the driver side. Either under the dash by the clutch or right inside the driver door.
Remove the drivers door panel and unplug the power door lock actuator, [door lock motor] and try the door locks again, if they work, replace drivers door lock actuator, if not pull and replace the "Power Door Lock Control unit". 94
