h22 traction problems?
Old Sep 19, 2002 | 08:49 PM
baybeboi's Avatar
Default h22 traction problems?
A friend of mine has got the h23 in his civic and has traction problems. I wanted to do the h22 swap but then his car with an h23 already has traction problems. Are there ways to lessen traction? If so.. what?.. Thanks.
Old Sep 19, 2002 | 10:33 PM
Kamin's Avatar
Default Re: h22 traction problems? (baybeboi)
um what?
your gonna have problems with ANY h series engine.
i hope that helped
the only thing you can do is stickier tires or smaller engine.
Old Sep 20, 2002 | 12:53 AM
riceboy's Avatar
Default Re: h22 traction problems? (KAMiN)
BFG Drag Radials
Old Sep 20, 2002 | 06:44 AM
BoM's Avatar
BoM
Default Re: h22 traction problems? (riceboy)
SLICKS only.
Old Sep 20, 2002 | 12:53 PM
H22EK's Avatar
BFG Drag Radials
this is very true and learn how to drive it is the key to your sucess, learn how to feather the throttle not just stab the shi* out of it and you will be on your way.
Old Sep 20, 2002 | 06:16 PM
racecarpete's Avatar
Default Re: h22 traction problems? (H22EK)
i got a question for you guys. Is the traction problem because of weight or what? Is the civic too light for the h22? Just wondering cause i have a LOT of weight in my trunk cause i comete in usac and was wondering if i would still have these traction problems even though my car is pushing stock lude weight right now.
Old Sep 20, 2002 | 10:54 PM
heiyu's Avatar
Default Re: h22 traction problems? (SilverCivic2k)
you need the weight up front not the trunk. also theres a big problem with traction due to --light civic--high torque(well for a honda motor)h22---
Like the guys said earlier feather and get stickier tires.
Old Sep 21, 2002 | 03:27 PM
00WhiteEKy's Avatar
Default Re: h22 traction problems? (heiyu)
Yup. I have a gsr in my civic, I learned how to feather the clutch and not floor it and the car launchs so much better(don't drop the clutch at liek 3 grand, or your jsut do a big burnout, and have to shift to second right away, and loose all your rpm's, but get sticky tires, and maybe some suspention.
Old Sep 21, 2002 | 06:02 PM
Jonathan_ED3's Avatar
um what?
i hope that helped
You're going to have traction problems with ANY high HP/TQ levels.
How come when people have traction problems with a turbo setup it's cuz the engine is soooooo powerful.
But when you have almost the same power in an H series, it's the 'heavy *** engine's fault?
Old Sep 21, 2002 | 08:56 PM
00WhiteEKy's Avatar
Default Re: h22 traction problems? (hot_EG)
I don't think people say the motor is too heavy, cause any idiot can think for a second and figure out that if you put more weight in the front, over the tires that spin, that it will get better traction. WHy do I put sand bags in my truck in winter, to get better traction. Don't think yoru engine is too heavy, having a ton of weight in the back of your civic won't help the traction problem. And Unless you have like 10 15" subs in your civic, i doubt its at the weight of a lude. But even if you have the h22 in a lude, you can still dump the clutch and have traction problems. A metro can have traction problems if you rev the **** out of it and dump the clutch. Just drive your car around and get use to it, then get sticky tires. but don't burn out your clutch practicing your launch. I hope that helps. Good luck
Old Sep 22, 2002 | 06:55 AM
DR. ON POINT's Avatar
Banned
Default Re: h22 traction problems? (92hatchy)
drag radials are ur friend
5thgenlude01
Jan 13, 2009 05:15 PM
force-fed
Jan 31, 2006 08:50 PM
KTeller8
Oct 28, 2003 08:55 PM
ImPoRtz
Jun 23, 2002 05:18 AM
.nate
11
Feb 8, 2002 06:51 AM
