Smoking d15z1 has oil on exhaust port of header
Old Oct 13, 2010 | 05:22 PM
andocommando's Avatar
Default Smoking d15z1 has oil on exhaust port of header
before starting up my d15z1 swap i replaced the header on it and found that one of the exhaust ports was completely coated in oil
i checked the top of the spark plug to see if it was covered with oil but it was dry
how else would it be getting in there?
Old Oct 14, 2010 | 08:36 PM
kzelisko's Avatar
Default Re: smokin d15z1
Most likely a bad valve seal and/or valve guide.
Old Oct 15, 2010 | 03:20 PM
Default Re: Smoking d15z1 has oil on exhaust port of header
how would i check which one it is and how would i fix that?
Old Oct 15, 2010 | 04:44 PM
kzelisko's Avatar
You might be able to pull the valve cover and inspect the valves and find whats wrong. Unfortunately you're usually stuck pulling the head and taking it to a machine shop to have it checked.
Old Oct 15, 2010 | 05:58 PM
is this a project that would be easier to have a shop do? and how much would a fair price be for this type of thing?
Old Oct 15, 2010 | 06:24 PM
nus_dogg's Avatar
I'm with Kzelisko.
Old Oct 15, 2010 | 07:45 PM
itsmejto's Avatar
Don't assume there is ANYTHING wrong yet unless you actually run it.
The oil is probably a leak by if stored on it's side etc, especially as you say the plug looks ok.
Maddvtec
Dec 17, 2010 08:53 AM
rick_rabies
Jul 30, 2009 08:20 AM
kornerk12
Jul 20, 2008 07:49 PM
bresk8r87
Jan 6, 2006 01:59 PM
SpeedMachine
Apr 29, 2005 12:27 AM
