Smoking d15z1 has oil on exhaust port of header
Old 10-13-2010, 05:22 PM
andocommando's Avatar
Default Smoking d15z1 has oil on exhaust port of header
before starting up my d15z1 swap i replaced the header on it and found that one of the exhaust ports was completely coated in oil
i checked the top of the spark plug to see if it was covered with oil but it was dry
how else would it be getting in there?
Old 10-14-2010, 08:36 PM
kzelisko's Avatar
Default Re: smokin d15z1
Most likely a bad valve seal and/or valve guide.
Old 10-15-2010, 03:20 PM
Default Re: Smoking d15z1 has oil on exhaust port of header
how would i check which one it is and how would i fix that?
Old 10-15-2010, 04:44 PM
kzelisko's Avatar
You might be able to pull the valve cover and inspect the valves and find whats wrong. Unfortunately you're usually stuck pulling the head and taking it to a machine shop to have it checked.
Old 10-15-2010, 05:58 PM
is this a project that would be easier to have a shop do? and how much would a fair price be for this type of thing?
Old 10-15-2010, 06:24 PM
nus_dogg's Avatar
I'm with Kzelisko.
Old 10-15-2010, 07:45 PM
itsmejto's Avatar
Don't assume there is ANYTHING wrong yet unless you actually run it.
The oil is probably a leak by if stored on it's side etc, especially as you say the plug looks ok.
Maddvtec
12-17-2010 08:53 AM
rick_rabies
07-30-2009 08:20 AM
kornerk12
07-20-2008 07:49 PM
bresk8r87
01-06-2006 01:59 PM
SpeedMachine
04-29-2005 12:27 AM
Quick Reply: Smoking d15z1 has oil on exhaust port of header
