Transmission & Drivetrain Gearboxes, Differentials, Clutches
Curse of the '90 Hatch, new problem with transmission, please help
Old Oct 13, 2010 | 10:00 AM
Nooch's Avatar
Default Curse of the '90 Hatch, new problem with transmission, please help
Car: 90 DX hatch
Engine: SOHC ZC 1.6L
Trany: SI 5 Speed
Currently my 5th gear will not engage. I can shift smoothly from 1st-4th and reverse as well but when I try to engage 5th gear it feels like it is up against a wall.
Please post things to check, as transmissions are NOT my thing.
Does not go into 5th while car's off.
Also ever since I did my engine swap the exhaust system moved slightly to the right, about an inch or so. The previous owner put a short shifter on the car and right after the engine swap the short shifter would hit the heat shield on the exhaust. I figured it would cause any problems so I just dented the side of the heat shield to **** so it wouldn't rub when shifting to 5th or Reverse.
I don't believe the short shifter is the problem.
Nooch
Oct 13, 2010 12:46 PM
snzh22
Aug 19, 2007 09:51 AM
6SPD_EK
Sep 11, 2006 05:05 AM
NA.GEORGE
Dec 28, 2004 09:46 PM
Acura97GSR
Jun 29, 2001 07:39 AM
