Suspension & Brakes Theory, alignment, spring rates....
need help: how to lower car.
Old Oct 12, 2010 | 01:42 PM
jk11110's Avatar
Icon2 need help: how to lower car.
i got an 03 honda civic ex and i want to lower it.
there are a couple ways ive been suggested. one was using coilovers with the stock struts. is that a good or bad idea? i need your opinions.
Old Oct 12, 2010 | 01:58 PM
singlecamslamed's Avatar
Stage 3 CLINGER!
Default Re: need help: how to lower car.
Don't use stock struts. They'll blow quickly, and you'll bounce. Lol.
It depends on what your going for. If you want to got 1"-1.5" drop, just get springs and upgraded shocks/struts.
If you want 2" and lower, get a coilover & strut combo. Koni + Ground Control is one of the most widely used suspension setups. Especially for daily drivers. And you pick you spring rates n such. Progress CS2 is a good coilover setup for the money.
Old Oct 12, 2010 | 06:10 PM
jk11110's Avatar
alright thanks. what do you think about the koni shocks and the skunk2 coilovers?
Old Oct 12, 2010 | 06:35 PM
TunerN00b's Avatar
The springs used on most of the Skunk2 sleeves are very stiff. If that is what you want, ride quality wise, then go for it. If you want comfort, I'd stay away without first getting the exact rates they use to make a final determination.
Since you just want it lower, I think lowering springs would be much better than any performance or "slammed / dumped" oriented sleeve kits.
Old Oct 12, 2010 | 06:43 PM
Stage 3 CLINGER!
I have skunk2 and tokico setup. I don't really like it. It's pretty stiff and semi bouncy. But it works for now.
Old Oct 12, 2010 | 07:08 PM
98civdx's Avatar
Master Detailer
My skunk2's are the same.
My friend was runing skunk2 slip ons illumnias and it wasn't to bad. Was stiff and rarly bounched. Only on large bumps.
Old Oct 12, 2010 | 07:39 PM
ej6kid's Avatar
I had skunk2 springs on koni oranges ride wasntto bad but bounced little bit. I just changed to kyb agx and megan racing sleeves. Love the ride isnt to stiff not to bouncy i like it alot
Old Oct 12, 2010 | 07:41 PM
ej6kid's Avatar
Also. If the 03 civic si and the ex suspension is compatible. Visit raceland.com they have dumb cheap coilovers for the ep3 which are same years as your ex. Plus i heard racelands are great esp for the money. Just a thought bro. Goodluck
Old Oct 12, 2010 | 08:41 PM
Stage 3 CLINGER!
^He'll have to drill something out. It's only direct bolt on for the 04-05 Civic's. There's a 16mm bolt instead of a 14mm bolt on the 01-03's. Just an fyi.
Old Oct 13, 2010 | 07:16 AM
ej6kid's Avatar
Ah i gotchya. Yeah man i wasnt to sure how all that worked figured if i threw out the idea someone would know lol
Phinehondaex99
Suspension & Brakes
Feb 16, 2012 08:04 AM
fatboys_ef9
Suspension & Brakes
Jul 9, 2010 06:46 PM
D3vin
Suspension & Brakes
14
Apr 17, 2009 05:06 PM
ham
Feb 3, 2005 08:35 AM
NVBAM
Jul 2, 2002 11:00 AM
