Wife left ebrake on for 3 mile trip...
Old Oct 12, 2010 | 11:37 AM
Didly's Avatar
Default Wife left ebrake on for 3 mile trip...
Okay so my wife drove down the street today to the store (first time driving the new 96 civic hatch dx) with the ebrake fully engaged.
She asks "why is it so slow, i floored it and it barely went anywhere"
then she says "and the back end squeeks alot" first thing i thought was ebrake...
So i take the car for a drive seems okay.. then i tried to drive with the ebrake on and it squeeked like hell and really wouldnt GO.
Well now the rear brakes (drum) squeek when I brake hard now..
My question is what else should i look for besides just replacing the brake shoes.
The engine was real hot.. (i didnt check the temp guage) But I popped the hood to check the fluid level and even the hood latch was scorching
My guess is because the engine had to work its *** off just to move..
Please dont turn this into your wifes an idiot.... I would have ____ ___ _____. Kind of thing.. I already flipped out on her enough and I actually feel kinda bad.
But what else should I look for
Thanks in advance
Didly
Old Oct 12, 2010 | 12:44 PM
engineer2's Avatar
Default Re: Wife left ebrake on for 3 mile trip...
Well it couldn't have been set that hard or it would just drag the rear tires.
With luck, only new shoes, turn the drums, and lube the backing plate contact points (normal drum brake job stuff). Really won't know untill you pull it apart. If there is rear brake carnage, please post pix.
Old Oct 12, 2010 | 02:52 PM
Ci-v-iC's Avatar
Consider changing the drums completely if you still have the originals...they are pretty cheap. Otherwise, I don't think you have too much damage but check the pistons for leaks- sounds like the shoes were ready to go anyways...
Old Oct 12, 2010 | 02:55 PM
ke98248's Avatar
Replace the rear drums and shoes, should be good but take the rear brakes off and check it out
Old Oct 12, 2010 | 03:46 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
I would suggest maybe checking the rear brakes to see if they're glazed or just need cleaning after being dragged. The noise might just go away by itself. Besides that, I would suggest leaving it alone. It was only 3 miles. Don't worry about the car overheating. It didn't. Don't flip out on your wife. They're just brakes. They're like $30. Not worth flipping out. Remember...she knows where you sleep....
My GF breaks all my stuff. It's just how they roll. You should feel bad for flipping out on her.
Old Oct 12, 2010 | 03:48 PM
Rude Awakening's Avatar
Daughter not possible
As good as time as any for a rear disc swap.
Old Oct 12, 2010 | 03:52 PM
94EG8's Avatar
Seagull Management
I've run with rear brakes on for like 15 miles before, didn't seem to do any damage. was on an old dodge dakota.
Old Oct 12, 2010 | 03:54 PM
Dontoh's Avatar
Old Oct 12, 2010 | 05:57 PM
mattyfo0z's Avatar
How did you park your Civic in the kitchen?
Old Oct 12, 2010 | 06:01 PM
ss_zoidberg's Avatar
Lol, and thus it begins
Old Oct 12, 2010 | 06:10 PM
Didly's Avatar
Yeah so the noise went away. They are actually fine.. im going to open them up this week to be sure
I did feel bad lol I appologized to her.
@rude yeahs I've already been looking lol
@.mattyz I knew it would start somewhere...
Thanks everyone for all the responses
Old Oct 12, 2010 | 06:33 PM
schardbody's Avatar
i'd recommend scuffing the friction surface of the shoes with some 180 grit paper just to get the glazed surface off, clean em up and adjust them, then go reseat them.
i wouldnt worry about the drums since the heat should have been transferred evenly as the car was rolling, its not like panic stops where you will get hot spots.
also wouldnt be a bad idea to bleed them, or flush the fluid completely. if the pedal still feels great this isnt really needed, but never hurts.
Old Oct 12, 2010 | 06:43 PM
kaiba's Avatar
THIS THREAD IS WORTHLESS WITHOUT A PICTURE OF OP WIFE.
SeanK325's Avatar
haha
Old Oct 12, 2010 | 07:08 PM
Didly's Avatar
Hahahaha NEVER!!! Shes 450lbs DDD'S 44-48-55 just so u get an idea
Old Oct 12, 2010 | 08:58 PM
ke98248's Avatar
The thread has been answered, it's now getting out of hand.
Old Oct 12, 2010 | 11:19 PM
chewyv's Avatar
pm4nudes
Pics or no answer.
I'd freak out too.
Old Oct 12, 2010 | 11:25 PM
Accord_V6_400m's Avatar
Change out the brake fluid too, might be time for you to do so anyhow.
Old Oct 13, 2010 | 01:39 AM
Didly's Avatar
I'm sure it is I'm sure its probably black.. what is the bleed order again.?
Old Oct 13, 2010 | 02:16 AM
Libertariat's Avatar
Ek Forever y0!
this
trianglegreg
Dec 2, 2006 02:22 PM
Kn33gr0W
Feb 11, 2004 07:25 PM
thenick
Nov 12, 2002 07:50 PM
