Transmission & Drivetrain Gearboxes, Differentials, Clutches
FYI: B-series LS 64-tooth ring gear
Old Oct 12, 2010 | 10:29 AM
Honda Bull's Avatar
Default FYI: B-series LS 64-tooth ring gear
So, as luck would have it, I was only aware (as well as everyone else online it seems) about the LS 4.266 FD ring gear (64 teeth) having the B16/LS inner ring gear diameter of ~110 mm.
The one sitting on the bench right now is 64 teeth and 117 mm inner diameter, which fits the GSR/ITR diffs.
Only reason I caught it was because the owner broke a 4.9 FD, and was replacing it with a 4.400 he purchased used. So now, I get to explain to him that the seller is either stupid or lied, and why Honda would even make the 64 tooth ring gear to fit the ITR/GSR diff.
WTF, Honda???
Aquafina, Mistabone, Synchrotech... anyone else see this before?
Old Oct 12, 2010 | 10:48 AM
Honda Bull's Avatar
Default Re: FYI: B-series LS 64-tooth ring gear
After some searching, thinking it might be an H22 4.266 final drive. Ring gear has same inner diameter as the outside of the GSR/ITR diffs (117mm).
Old Oct 12, 2010 | 10:59 AM
Honda Bull's Avatar
Yep. Owner was definitely sent a Prelude ring gear and an unknown countershaft (15 tooth). lol Could be nearly any countershaft. I just didn't realize the Prelude diffs had the same dimensions as the B-series.
BlueTeg
Apr 2, 2014 01:00 AM
olddohc
Oct 10, 2012 02:04 PM
ToeJam
Feb 26, 2008 08:29 PM
fdavie
Aug 4, 2007 06:02 AM
SolidSpruce
Mar 26, 2003 07:43 PM
