HID Fog Light install help please
I'm attempting to use hids with my fog lights and i was wondeing if you who has done this in the past could help me out or atleast point me in the right direction to get help. Thnks
Its easy, all u need to do Is drill a hole in the back plat of the fog light housing as the back of the HID bulbs stick out about a half inch, then just cut and feed the wires through and re wire em together plug into ballast and your good to go. Then I just loaded up the back plat with caulk to seal up the hole to the bulb, did it 2 years ago and have had no issues with water leaking in what so ever.
Good Luck, hit me up if u have other questions
