b16 swap into 93 hatch - no starter signal
Old Oct 12, 2010 | 12:56 AM
fastfish13's Avatar
Default b16 swap into 93 hatch - no starter signal
just put in b16 into 93 hatch. turned key turned over but no fuel so i changed fuel pump. tryed to start again and now starter is not doing anything at all need advice all grounds are good plus no signal ???
Old Oct 12, 2010 | 02:50 AM
redeg666's Avatar
Default Re: b16 no starter signal
bad fuse
Old Oct 12, 2010 | 04:02 AM
Former User's Avatar
Is the transmission ground wire connected? Are both starter wires connected?
Old Oct 12, 2010 | 05:25 PM
fastfish13's Avatar
Default Re: b16 swap into 93 hatch - no starter signal
yeah all grounds are good, no voltage to starter signal wire at starter , ok havent put the axles on yet do they ground too? i tried a different starter relay still nothing can someone post a pic of which ones the starter relay so ican be 100% its the one i changed
Old Oct 12, 2010 | 06:19 PM
Hondatherdm's Avatar
getting any voltage at big wire at the starter?
Old Oct 12, 2010 | 06:34 PM
fastfish13's Avatar
yeah like 12
Old Oct 12, 2010 | 06:45 PM
fastfish13's Avatar
tryed a jumper from battery touch starter signal connecter i just clicks. touch it to the nut under rubber it spins but dosent engage. i might need a new starter but its still works so ive been trying every other thing it turned motor over the first tiime i turned key but the fuel pump wasnt priming and main relay was buzzing well i think it was main relay cause dash was on at time so i had some extra fuel pumps so i switch it out then starter didnt turn??? if the starter cut relay goes out will it buzz
Old Oct 12, 2010 | 06:48 PM
when relay buzzes that means low voltage from batt
Old Oct 12, 2010 | 08:19 PM
phaphon's Avatar
you can try push starting?
Old Oct 13, 2010 | 12:21 PM
fastfish13's Avatar
my axles rare not put on yet will that effect the grounding of motor
Old Oct 13, 2010 | 12:55 PM
No
Old Oct 16, 2010 | 10:35 AM
fastfish13's Avatar
ok i used a jumper at the starter relay turned key now i get a signal at starter but want spin??? i ordered a starter
Old Oct 27, 2010 | 05:26 AM
fastfish13's Avatar
ok ive replaced most of wiring still nothing at all when starter relay is pluged in ive tryed 3 when i use a jumper at the connecter at least i get whining and clicks need more advice if the shift linkage and axles help ground i really need to know cause i can put the motor in a another car and have it running in the time it takes to put that stuff on and it still not run! ok im not being a dick but come on now this is honda tech i should have like 200 post on how to fix my problem where are the roots of this forum or should i ask a body kit question the few people that responded thank u now please more feed back
Old Oct 27, 2010 | 05:36 AM
This doesn't help you.
Check whether the rubber stopper on the clutch pedal is broken or missing.
Old Oct 31, 2010 | 03:16 PM
fastfish13's Avatar
good call that was it thats the only thing i didnt recheck or replace thanks
slow_sihatch
16
Aug 4, 2015 04:35 PM
cksnah252
12
Sep 9, 2014 07:51 AM
Schultzie
Jan 23, 2013 09:46 PM
slowassBubble
May 15, 2011 07:50 AM
honda head
Jan 28, 2007 01:35 AM
