zc into my 97 dx HELP!
Old Oct 11, 2010 | 11:32 PM
r0ccsteady's Avatar
Default zc into my 97 dx HELP!
ok so i blew my stock y7. i ended up coming up on a zc (non vtec) off a ef. got the longblock including tranny, dist, starter and ecu and etc. everything but the harness. So i need to kno wat is all needed to make the swap work. can i jus drop it in and wire it up to my y7 harness and still use my current ecu? will i need a 0bd0-0bd2 conversion harness?? which ecu should i use?? damn im lost! somebody help a brotha out!!!
Old Oct 12, 2010 | 01:17 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: zc into my 97 dx HELP!
You're going to have to do a little work. If it swap you'll have to swap over the oil pump because the Y7 has the CKF sensor and magnet in that area. You might want to check into that before you start the block swap.
Old Oct 12, 2010 | 10:46 AM
r0ccsteady's Avatar
thanks ill make sure to check up on that.. wat about the wiring??
Old Oct 12, 2010 | 10:54 AM
Former User's Avatar
The older engine won't pass inspection/emissions/smog in CA.
dczcef91
Sep 4, 2012 06:22 PM
chevmaro
Jul 8, 2009 08:59 AM
pabloeg8
Sep 5, 2008 05:52 AM
ludecrasy87
Nov 29, 2006 12:24 PM
Crashoveride1913
Nov 15, 2005 08:41 AM
