Wheel Play
On my driver front wheel it has a little play when you push and pull the wheel by hand. I don't notice anything when I drive but what could that be. I did already check the wheel. Bearing maybe?
OP- It won't be your axle nut or balljoints. You're either looking at tie rods (if the wobble is only side to side) or wheel bearings if it in top to bottom wiggle.
09egkid
Aug 6, 2010 02:54 PM
