help, how do brakes work?
Old Sep 19, 2002 | 07:17 PM
d8168055's Avatar
Default help, how do brakes work?
I jsut visited howstuffworks.com and im even more confuzzzed. how exactly do disc brakes work? basically, how does the caliper grasping the rotor slow the car down? does the rotor move with the wheels? please help...
Old Sep 19, 2002 | 07:23 PM
Asahi's Avatar
Default Re: help, how do brakes work? (d8168055)
yes the rotor moves with the wheel. caliper is stationary
Old Sep 19, 2002 | 07:31 PM
d8168055's Avatar
Default Re: help, how do brakes work? (Asahi)
OH REALLY???????? that clears things up! thanks man..
Old Sep 19, 2002 | 08:00 PM
lotus's Avatar
New User
If you really want to blow your mind, figure out how a clutch works...
It's kind of neat really... Alot like an inboard disc brake..( like on a Jag or lotus )
Old Sep 19, 2002 | 08:11 PM
Cosworth's Avatar
Ask details to the mechanics, but basically...
1. push on the brake pedal
2. it pushes brake fluid down the brake lines
3. brake fluids pushes on the piston(s) of the calipers which is in contact with brake pads
4. brake pads are pushed towards the rotors
5. pads and rotors meet and friction occurs
6. enough friction = slow -> stop
what boggles my mind is how ECU and ABS can modulate the brakes... some crazy engineering on cars these days.
mouab18c1
Suspension & Brakes
Apr 10, 2009 06:53 AM
tjluvsahonda
Oct 4, 2007 08:09 AM
integra714
Sep 17, 2004 10:29 PM
Ninja Mike
May 27, 2004 07:20 PM
