94 civic overheating issue
I have a 94 ex with a jdm d15b swap in it. A couple weeks ago, i was driving through town and stopped. when i stopped the overflow tank was boiling but the engine temp was normal. i let it cool, put more coolant in it cause radiator was dry, then later let the car sit at idle and run and it didnt overheat at all and was good for a lil over a week. then i was on interstate going about 80 the whole way for 50 miles, and when i got off, it was boiling again and then engine temp was still at normal temp! i found out the switch that turns the fan on wasnt working properly so i fixed it and havent been on a long trip again yet, but does anyone have a clue as to what this problem is? there are no leaks or weird smells or anything. it jus randomly started happening. any help/suggestions would help, thanks.
i hope so. i didnt even think about that. lmao. the last time it overheated i put 50/50 in it and aint had a problem since. the other time, i used jus straight water. lol
it was just ur fan than... once u fix ur fan it stopped overheating right??? try this unplug ur fan and drive till ur car overheat or 20min or so... than let the car cool plug ur fan in and drive for 20min or so and see if ur car overheats
well i also haven't taken it on a long trip either. so it kinda hard to tell right now. but the water thing makes sense. i accidentally loosened a drain plug for the block a few weeks ago cause i wasnt sure what it went too cause it didnt look like a drain plug to me! LMAO. Terrible idea! so i retightened it and then put water back in it where i had lost coolant. then it overheated, then i put even more water in it, then it overheated again and i put 50/50 in it instead. i jus didnt think about the too much water thing for some reason. lol
ive got a 94 civic ex and cracked some plastic peice hanging off the bottom drove the rest of the way 2 the job it began 2 over heat repaird the crack filled up radiator and resivior and it still overheats ne help?
ANNiHiLATORS
Jun 4, 2012 07:53 PM
hatchet_honda
Mar 6, 2011 07:29 PM
Squad1
10
Oct 18, 2009 07:24 PM
