last few H22A ?s plz help
Old Oct 11, 2010 | 06:10 PM
92cb7sk8er's Avatar
Icon6 last few H22A ?s plz help
ok guys im down to my last few ? for you
1. Vacuum line #8 that runs out of a little black box on the front right side of the car is really long, well i have all of the vacuum lines out of the black bock running somewhere and i have no where that i know of to run #8. can i just close it off or does someone know where i can run it?
1. I have figured this one out already after I put the air intake on I found a plug at the bass where I just ran it to.
2. I have a coil pack pluged in but no coil wire running to the distrubutor my car still started though so do i need to have a coil pack? or its it inturnal? its a OBD-1 JDM H22A.
3. I have two wires left to plug in both are on the right side of the car by the distrubutor. One is an ovel shape and there is one just like it i have pluged into the tranny. The other is a green plug im pritty sure that i have all of the pluged in.
4. Now my last ? is there is a black cylinder next to the T. body and the V-tec solenoid it has the same kind of plug out as the map sensor but i used the F22A6 wiring harness so i only had one plug like that.. so do i need to run wires to this or just forget about it and what is it anyways?
here is a video showing what im asking above...
http://www.youtube.com/watch?v=vrSlBmOfoLE
Old Oct 11, 2010 | 09:26 PM
h22apwrcb7's Avatar
Default Re: last few H22A ?s plz help
the black plug by ur feul line is the egr valve, the square plug goes there but youhave to use the plug off the accord or just use the old valve either way works
the green plug is the temp sensor
btw you have to extend both plugs to reach
Old Oct 11, 2010 | 10:51 PM
holmesnmanny's Avatar
First off, you'd get a lot faster answers posting in the prelude forum. The h22 uses an internal coil. If your car has an external coil you have to convert it to an internal coil. That first vacuum hose goes onto the throttle body on the accord, not too sure about the prelude.
This is great help here..
http://www.ultimateresourceguides.co...eSwapGuide.pdf
Old Oct 12, 2010 | 04:43 AM
92cb7sk8er's Avatar
ok that works i can make it cleaner then thanks
aznoophi
Apr 3, 2008 06:05 AM
9deuce9rr
Jan 30, 2004 09:08 AM
95%
Apr 4, 2003 10:53 AM
rabalero
Mar 27, 2003 04:28 PM
