help... motor sutters in a d16a6
Old Oct 11, 2010 | 04:18 PM
jaycorolla's Avatar
Default help... motor sutters in a d16a6
need help... wife just bought a 89 honda civic hb si... head has been rebuilt but when going round the coner with the car placing it into second gear the motor stutter or hesitates at 3000rpm but when out of gear it revs fine...... anybody know whats causing the problem?
if problem is solve willing to give $20 reward for the right answer that solves the issue
Old Oct 11, 2010 | 04:28 PM
efjones9's Avatar
Default Re: help... motor sutters in a d16a6
might be the distributor. try to change the ignitor in the distributor and that should fix ur prob
Old Oct 11, 2010 | 07:02 PM
jaycorolla's Avatar
have brand new dizzy in it....
Old Oct 11, 2010 | 07:19 PM
BrandonR's Avatar
Tune up? Recent maintence? How about a check engine light? Need more description sir. -Later, BR
Old Oct 11, 2010 | 07:34 PM
jaycorolla's Avatar
no engine light... new dizzy.. tuned up... brand new ported n polished head, all new gaskets, head has been rebuilt..... all wire pluged in fine.... but when rev with out load it revs fine... when shifting into second gear it stutters at 300 rpm n then around 4500 it stops stuttering. but does it for every gear except first.
Old Oct 11, 2010 | 07:44 PM
BrandonR's Avatar
What was included in that tune-up? -Later, BR
Old Oct 11, 2010 | 08:31 PM
jaycorolla's Avatar
wires, plugs, bought whole new dissy..... and timing checked.
Old Oct 12, 2010 | 10:32 AM
efjones9's Avatar
hmmmm maybe tps? ecu? bad ground fuel filter/pump. could be a number of things
Old Oct 12, 2010 | 01:41 PM
BrandonR's Avatar
Could be a lazy oxygen sensor. If thats never been replaced i'd get a new one. -Later, BR
Old Oct 12, 2010 | 06:42 PM
jaycorolla's Avatar
new tps, new fuel filter, new ecu, but havent replaced the o2 sensor yet......
Old Oct 23, 2010 | 06:30 PM
jaycorolla's Avatar
still need help
Old Oct 23, 2010 | 08:58 PM
BrandonR's Avatar
What have you done? You said you haven't replaced the O2 yet... -Later, BR
Old Oct 30, 2010 | 12:22 AM
jaycorolla's Avatar
replace the o2 sensor and still having it stutter when pressing full throttle
Old Oct 30, 2010 | 07:44 AM
BrandonR's Avatar
Define this stutter? Like a miss fire stutter?
jj48_winner
21
Aug 19, 2016 11:05 AM
ChrisVTEC
Jun 18, 2015 05:37 AM
febru_16
Jan 31, 2010 01:04 PM
ClubRX
Jun 20, 2006 11:10 PM
R249
Feb 13, 2003 02:49 PM
