16x9 +9????
Old Oct 11, 2010 | 01:12 PM
Hon Dub's Avatar
Default 16x9 +9????
Looking at a set of wheels that are 16x9 +9 in the rear. I was wondering if anyone could give me an idea as to whether these could fit in the rear of an ek hatch if I do not roll the rear fenders? Reason being there was some filler used in shaping the rear and rolling may be too risky to do.
I would be stretching/going negative camber with these. Thanks all.
Old Oct 11, 2010 | 04:09 PM
toyomatt84's Avatar
Sanji
Default Re: 16x9 +9????
Without the fenders being rolled, I highly doubt you'll fit much wider than a 7.5" with about a +15 offset.
Old Oct 11, 2010 | 08:48 PM
Hon Dub's Avatar
thanks matt. what if I grind off the lips in the rear?
Old Oct 12, 2010 | 07:48 AM
toyomatt84's Avatar
Sanji
It's still going to be difficult. You may get away with it, but I have a sneaking suspicion that you'll rub.
Old Oct 12, 2010 | 11:48 AM
nsxtasy's Avatar
H-T Order of Merit
FIRST decide on what size tire you are going to get. THEN find a wheel whose width fits.
On a '97-00 Civic with 16" wheels, you should be using 205/45-16 or 215/45-16 tires. 16x9 is too wide for either of those tire sizes. 205/45-16 should not be mounted on wheels wider than 16x7.5. 215/45-16 can be mounted on 16x8 but no wider. I recommend 16x7 so you can use either 16" tire size.
Old Oct 12, 2010 | 06:32 PM
Hon Dub's Avatar
thanks nsxtasy, jenkins do you have anything you can add? I really like these wheels and would love to have them I just hope it would be possible to fit them, but if not oh well.
Old Oct 12, 2010 | 08:58 PM
r.wright's Avatar
i would suggest grinding them if you are scared.
and go shopping for camber arms that can adjust to negative if u do not like the stance...n if u plan on dailying this car look into a shop that works on lowered cars n offers lifetime wheel alignments.
Old Oct 14, 2010 | 09:44 AM
Hon Dub's Avatar
so you guys think if I grind the lips and camber the rear with a slightly stretched tire I could make it work in the rear even if I am low?
Old Oct 14, 2010 | 09:55 AM
r.wright's Avatar
thats your only way unless you want to run fender flares on normal sized tires like a 225...
what ever u do be careful.
bldzrr
Aug 24, 2018 07:12 AM
01_ITR
Jan 13, 2009 08:54 PM
cmdr430
Honda S2000
Oct 26, 2006 11:03 AM
sebmour jdm
Honda S2000
11
May 27, 2005 02:27 PM
9k4play
Honda S2000
11
Jan 5, 2004 04:12 PM
