JDM OBDII H22A Swap - Wiring
OK, I did a lot of research, but found nothing entirely solid. I am doing a OBDII JDM H22A swap into a 98 Base.
When wiring the CKP wires into the JDM OBDII internal coil distributor, what color wires from the USDM CKP harness is spliced into what color on the JDM dizzy?
Also are the colors like for like when swapping the USDM harness dizzy plugs with the JDM harness dizzy plugs? That is the only way I can see being able to plug into the JDM dizzy.
I was wondering if it is possible to convert to the USDM external coil distributor and also relocate the CKP wires from the oil pan housing up into the distributor?
Any info would be helpful.
well first if your using a jdm engine, the harness on that engine won't work so i hope you used the harness that came with the car. you can use your (dizzy) off the usdm engine.
