hydro car..cable tranny help
i have been building a car for a guy down the street. its an ek with a built ls vtec turbo. the problem i am having is the tranny he picked up is a cable tranny. i have been looking for a conversion kit but not sure which one is right. also i have been looking for a hydro tranny casing to just swap the casings. can anyone point me in the right direction for a kit and maybe a link as to how the kit looks after installed or how to intall it
this is the kit im looking at but would like to see pics of it on the car
http://hasport.com/store/index.php/ekcc.html
If I were you, I would just swap over the casings. I did mine the opposite direction (hydro gears to cable casing) for my 92 Integra.
Any B-series Hydraulic transmission is fully interchangable with any 92+ cable transmission. If you have a factory LSD but a case without LSD, it will require a tinybit of grinding. I'm not sure if the same clearance issues exist for aftermarket LSDs though.
Swapping over everything is a really simple procedure, I'm astonished at why more poeple don't do this swap. You have Honda clutch feel and reliability, save yourself quite alot of money, and also dont have wait for your conversion kit to arrive. LS B-series transmissions can be found fairly cheap as well. just make sure to measure the differential pre-load, and mainshaft thrust clearances and get shims accordingly.
Here is a very good write up about this, but for hydro-> cable. Going from Cable -> Hydro is the same procedure.
http://www.3geez.com/forum/showthread.php?t=68655.
88civichbz6
Jan 29, 2005 06:07 PM
