CRX EF OBD 0 to OBD 1 conversion. Distributor problems (CKP)
Old Oct 11, 2010 | 06:53 AM
raptor15's Avatar
Default CRX EF OBD 0 to OBD 1 conversion. Distributor problems (CKP)
I am trying to set up a customers EF to run s300.
This is the setup:
b16a head
b20b block
h22a injectors
type r b16b distributor
vtec frog obd 0 to obd 1 conversion harness
p08 ecu with s300.
previous ecu was pw0 and using obd 0 distributor with the rest of the above mentioned set up.
The problem is i cant get rid of the DTC code 4 CKP crank angle sensor
the vtec frog wiring instructions mentioned they had already swapped the ckpp with the cypp wires so i referred to the hondata ecu pin out diagram to confirm that and wired in the dizzy accordingly.
At first crank the engine started up no issues but displayed check code 4 and would not rev past 3500. So i swapped out the distributor for a dc2 confirmed working obd 2 dizzy... still same problem after clearing the dlc's.
I tried tracing back the wires and just tried swapping over ckpp and cypp as well as ckpm and cypm.
the engine would not start. so i just went back to the way it was originally wired. i am unable to think of what else might be wrong. all wiring connections are good.
i hope someone can give me some helpful advice.
cheers
JuneBugDrfter
Aug 8, 2013 12:39 PM
PrecisionPerformanceParts
Jul 28, 2005 10:23 PM
DOHC D16Y8
Apr 19, 2005 07:01 AM
crxhybrid1320
Jun 9, 2004 07:42 PM
