96 civic dx - trying to figure out what i should do for it
Old Oct 10, 2010 | 11:04 PM
ChristeanBrown's Avatar
Icon6 96 civic dx - trying to figure out what i should do for it
hey everyone. well i recently bought a 96 civic dx and i'm trying to figure out what i should do for it. idk alot about hondas but i'm trying to learn. so anyone with any info about what i should do just hit me up thanks.
Old Oct 11, 2010 | 05:30 AM
Former User's Avatar
Default Re: 96 civic dx - trying to figure out what i should do for it
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
Old Oct 11, 2010 | 08:12 AM
b20hatchek's Avatar
can we getta pic of the car and so more info on the car?
Old Oct 11, 2010 | 08:21 AM
silverbullet9626's Avatar
dont do anything ive got a 96 dx. ive done an engine swap 2 yrs ago and still cant get it to pass emissions. part of the reason is because the swap i chose. if you wanna go DOHC VTEC
your in for a nightmare because the dx doesnt have an EVAP system. because most b series engines/ecu's look for the evap system you have to change the fuel tank and add the evap lines from the front to the back. basically what im tryin to say is the car is a base model with minimal features that higher trim models have making modding the car and passing emissions harder
Old Oct 11, 2010 | 08:29 AM
b20hatchek's Avatar
wtf?^ swap tanks? never ever heard of that, it doesnt matter if it's a dx. it should atleast have a d16y8 in it so you can use the harness on a obd1 dohc vtec engine and swap the injectors and if you want (it's easier) swap the dizzy and alternator and run a conversion jumper harness to run a obd1 ecu and your done, ran a gsr swap in a dx coupe that way
Old Oct 11, 2010 | 06:39 PM
it won't let me post attachments yet. umm it's just a stock d16y7 with a cold air intake. the cold air intake was already on the car when i got it, all i did was extend it.
Old Oct 11, 2010 | 10:12 PM
b20hatchek's Avatar
personally i would just enjoy it for what it is, save up for a b-series swap or like all the kids on here just boost the d
Old Oct 12, 2010 | 10:08 AM
yep same engine i had you will get bored with it quick. it doesnt have the evap system but really the evap system is on the car the only thing it has to do with the engine is a sensor and some lines on the fuel rail. the rest is lines to the back and some sensors built on or into the tank. i have researched this as ive had my swap for 2 yrs and still havent passed emissions
Old Oct 12, 2010 | 12:51 PM
engineer2's Avatar
A DX doesn't have sway bars. Easy ugrade from salvage yard parts.
Old Oct 12, 2010 | 01:37 PM
b20hatchek's Avatar
their are no sensors in the tank, the only thing in the tank is the fuel pump, i don't care if you've had your swap for 2 years ive done more swap within that time frame to know you don't have to do all of that crap
Old Oct 12, 2010 | 01:40 PM
Failsafe88's Avatar
no real need for sway bars till he decides if really will build it. i have cheap turbo parts easiest thing to do for power with that motor you will come to find out.
Old Oct 12, 2010 | 01:44 PM
b20hatchek's Avatar
yea when he knows nothing about the motor and boost it then, pop!
Old Oct 12, 2010 | 09:23 PM
right now i'm just trying to learn everything i can. i wanna get familiar with everything and then i'll decide what to do, i'm thinking like a mini me conversion or save up for a b series.
Old Oct 13, 2010 | 03:37 PM
b20hatchek's Avatar
That's what i'd do, b-series swap
Old Oct 13, 2010 | 05:36 PM
alright. i'm not really trying to make the d fast, i just wanna get experience with it. i don't want to get a b and not know what i'm doing haah.
Old Oct 14, 2010 | 05:09 PM
one thing, it's got like 246k miles on it. is that too much, should i just save up for a whole new engine or is that good?
Old Oct 16, 2010 | 07:33 PM
b20hatchek's Avatar
depends on how it runs but i wouldnt change much on the motor as it could cause some problems in the future
Old Oct 16, 2010 | 09:05 PM
chewyv's Avatar
pm4nudes
emmissions testing was removed from my state.
Unlimited swap abuse here.
Old Oct 17, 2010 | 10:53 AM
i'm thinking i'll just save up for a new motor. and have this one just to mess around with.
Old Oct 17, 2010 | 11:43 AM
poolv23's Avatar
ya i got the y7 too... i would just work on suspension first bro then if you need it painted do that, then do some engine work.. the possibly get a lip kit. those are my plans.
poolv23's Avatar
if your not interested in a motor swap just get a vtech head bro.
Old Oct 19, 2010 | 01:42 PM
so what should i do with the suspension. and i'm going to get it painted because my aunt ran into it :/
skUnK2jdm
16
Apr 17, 2008 04:05 PM
rem177
19
May 20, 2004 07:56 PM
