where is tcu/tcm? 2000 teg
Old Oct 10, 2010 | 08:41 PM
b18bcoupe's Avatar
Default where is tcu/tcm? 2000 teg
Hi,
Can anyone please tell me where the TCU or TCM (transmission control unit or module) is located? Thank you very much.
Old Oct 10, 2010 | 08:48 PM
Spawne32's Avatar
Default Re: where is tcu/tcm? 2000 teg
there is none, it is controlled via the ECU on obd2b systems
Old Oct 10, 2010 | 09:08 PM
b18bcoupe's Avatar
excellent, thank you for the reply. I began to suspect as much because I took the car apart and found nothing. Would you also happen to know how I can make an OBDIIB auto transmission run in a 92-95 civic?
thanks again.
Old Oct 10, 2010 | 09:14 PM
Spawne32's Avatar
mmmm, not sure how that would work seeing as how the controls for the tranny are mated with the ECU, and vice versa. You wouldnt be able to convert to an obd1 setup with that trans i believe. But dont quote me on that.
Old Oct 10, 2010 | 09:55 PM
b18bcoupe's Avatar
yeah it could be hard: would have to wire in a TCM and an OBD1 ECU. I was thinking, what if I just swap ALL the wiring from the teg, including cluster, fuses, relays, and everything into the civic. That would just transfer the teg setup directly, which is guaranteed to run the tranny and engine perfectly. My only concern with this approach would be the question of whether all the sensors and accessories in the body of the civic can mate ok with the teg body harness.
Old Oct 11, 2010 | 06:42 AM
fcm's Avatar
fcm
Old Fart
There may be an aftermarket TCU available, we are in the process of installing/wiring a TCI, [aftermarket programmable TCU] in a 58 Chev PU powered by a big block, [572] Chev crate engine. the TCI unit is specific to a Chev, but there may be ones for Acura, Google is your friend. 94
Old Apr 25, 2012 | 07:37 PM
b18bcoupe's Avatar
See what a persistent b***ard I am? And how helpful and omnipresent fcm is? look at this thread...!
and this...
https://honda-tech.com/forums/hybrid-engine-swaps-18/b18b1-auto-swap-into-ej-civic-2847150/
to this!
https://honda-tech.com/forums/acura-integra-6/injectors-not-firing-3048614/
Tegraracer90
Mar 2, 2009 11:11 AM
Wes90civic
Jun 17, 2006 02:39 PM
Jer'rome
Mar 16, 2004 10:08 AM
Civic_EX_turbo
Jan 21, 2004 02:36 PM
squirrel
May 11, 2003 09:29 AM
