Suspension & Brakes Theory, alignment, spring rates....
Integra shocks that were on a Civic without washers won't fit Integra anymore
Old Oct 10, 2010 | 08:31 PM
so simple's Avatar
Default Integra shocks that were on a Civic without washers won't fit Integra anymore
So I have some Integra spec coilovers that came off a 96-00 Civic. Well, guess that person didn't use washers on the Civic, so the rear lower shock that bolts to the lca is bent/pinched in, so its too thin to fit over my Integra LCA now. I tried using a hammer and a panel tool to bend it back straight, but it's pretty tough.
Any recommendations?
Old Oct 11, 2010 | 07:05 AM
98civdx's Avatar
Master Detailer
Default Re: Integra shocks that were on a Civic without washers won't fit Integra anymore
My freind did this crap, we had to to put the shock in a clamp and heat it up.
Old Oct 11, 2010 | 07:57 AM
so simple's Avatar
i figured itd be something like that. its too tough to bend at normal temperatures right?
ive never used a torch before, how do i know how hot to heat it up? just want to make sure i dont melt the thing off.
Old Oct 11, 2010 | 08:11 AM
gabebauman's Avatar
Will your Honda scissor jack fit in there?
Old Oct 11, 2010 | 08:34 AM
so simple's Avatar
nope, the gap is only like 2" or so
Old Oct 11, 2010 | 10:00 AM
98civdx's Avatar
Master Detailer
Yea, we couldn't find anything to bend it, or try putting one end in the clamp and try to use the shock as leverage?
What I did was heat it up slowly while trying to move it at the same time. We used map gas, but if you have used a torch before I wouldnt reccomend it.
Try bending it wil the clamp first though
Old Oct 11, 2010 | 02:25 PM
Fo-Do Fanatic's Avatar
Whatever you do MAKE SURE you either wrap the shock bodies in cold wet rags or put ice packs on them to make sure you doing boil the gases/oil inside the shock. THey'll be ruined forever.
Old Oct 11, 2010 | 03:36 PM
98civdx's Avatar
Master Detailer
he's right.
I forgot to mention we did cover the shock with damp rags.
Old Oct 15, 2010 | 08:04 AM
so simple's Avatar
i bought one of those $20 bernzomatic things. will that work? how long should i hold it to the shock mounting point for?
Old Oct 15, 2010 | 01:00 PM
98civdx's Avatar
Master Detailer
That should do the job.
I honestly cant tell how long, just carefully heat it up and try bending it while heating.
Thats what we did.
huntarrr
Aug 2, 2006 01:01 PM
Tuesdaynightfever
Mar 20, 2006 10:45 AM
jd_659_56244
Feb 10, 2004 07:27 PM
216.226.142.95:27016
Sep 6, 2003 06:12 PM
