LS rev-limiter problem
Old Oct 10, 2010 | 05:48 PM
94HatchLS's Avatar
Default LS rev-limiter problem
I have a 94 hatch, with a new LS swap. It has been running completely fine since the swap. Than all of a sudden this morning on the way to work,
All through 5 gears i hit rev-limiter at 2000rpms. I went over all my grounds, reset the ECU. Oil change/tune up is two days old. Anyone have any suggestions?
Old Oct 10, 2010 | 08:00 PM
20-EM2-05's Avatar
Default Re: LS rev-limiter problem
What ECU are you running on?
Any CEL's?
Old Oct 11, 2010 | 02:41 AM
kpjo4's Avatar
If it's automatic most likely it's in limpmode.
Old Oct 11, 2010 | 07:22 AM
94HatchLS's Avatar
Stock ecu. limpmode?
Old Oct 11, 2010 | 07:26 AM
94HatchLS's Avatar
and its 5 speed
Old Oct 11, 2010 | 07:45 AM
SIM Racing's Avatar
Limpmode has arrived. try a new distributor after it is fixed. you have pinholes in it that are getting moisture inside and causing this. sometimes it will do it at 3500 rpms and sometimes at 2000. i had both happen to my civic hatch with a 95 ls swap. new dizzy and it never happened again.
Old Oct 11, 2010 | 07:50 AM
b20hatchek's Avatar
mine was the wiring going back to the ecu from the jumper harness
punxsk8r555
Feb 14, 2010 05:20 PM
mc_civic213
Apr 10, 2008 02:05 AM
slammed00si
Feb 23, 2007 10:04 AM
baked_beanz
Jul 24, 2005 02:09 PM
B_1_8_hatch
Dec 21, 2002 01:15 AM
