Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
LED Strip-Trunk Lighting-NEED HELP PLEASE
Old Oct 10, 2010 | 02:11 PM
JDM_WHR's Avatar
Icon2 LED Strip-Trunk Lighting-NEED HELP PLEASE
I bought an LED strip and wanted to install it in the trunk, to give more lighting. I figured I could splice into the Trunk Light, but when I tried connecting the wires, Only the Trunk light work, the LED strip didn't come on at all.
I should just have to splice into wires only right?
So, Question is do I go Red to White & Black to Blue OR Red to Blue & Black to White?
The LED strip has just Red & Black wire.
OEM harness is Blue & White.
ANY HELP would be GREAT!
Old Oct 10, 2010 | 07:01 PM
JDM_WHR's Avatar
Default Re: LED Strip-Trunk Lighting-NEED HELP PLEASE
HELP PLEASE!
Old Oct 11, 2010 | 07:07 PM
instructor74's Avatar
you need a DMM to test the voltage on the trunk light wiring you need to find out which wire is + and which wire is - than tap the red wire to the + and the black to the -. The other thing you need to know is is the led light bar 12 volts?
Old Oct 13, 2010 | 06:36 AM
JDM_WHR's Avatar
yes, the light bar is 12 volts, why?
Old Oct 20, 2010 | 07:04 PM
K-TUNER's Avatar
what I did was I left the trunk light mounted, but I cut the wires and soldered them directly to the LED and I haven't had any problems>
Old Oct 21, 2010 | 06:01 PM
bkindness's Avatar
Are u sure for that??
Old Oct 29, 2010 | 05:23 PM
JDM_WHR's Avatar
shadow4510
Feb 16, 2012 11:36 PM
ken9
Honda Civic (2001 - 2005)
Dec 5, 2008 09:09 AM
SalmanzCivic
Mar 13, 2005 03:29 PM
